Results 1 to 2 of 2
    Super Member
    AutoCAD 2010
    Dec 2010
    1,230
    Default disable the Edit in-place dialog box
    hi
    is there a way to disable the Edit in-place dialog box? (the one that popup when you enter to that isolation state and asking about opening nested blocks)
    Thanks
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    -REFEDIT should do it if you just want to suppress the dialog box for command line version.
    If you want to disable a command
    For disabling a required command use the "_UNDEFINE" command followed by name of the undefined command.
  1. Xref - can't Edit In Place
    By fostertom in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 17th Sep 2014, 03:50 pm
  2. edit in place x-ref
    By astonrenoir in forum Architecture & ADT
    Last Post: 4th Jul 2010, 03:03 pm
  3. Edit Xref In Place
    By kwortman in forum AutoCAD Drawing Management & Output
    Last Post: 26th Sep 2009, 05:21 am
  4. In Place Edit - NO DIALOG !
    By chavlji in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Mar 2009, 07:44 pm
  5. Xref Edit at Place!!
    By CadCodes in forum AutoCAD Beginners' Area
    Last Post: 2nd May 2007, 01:52 pm
