ira Posted July 26, 2017 Share Posted July 26, 2017 Hello everyone, I am trying to morph over from Turbocad to solidworks but I am not doeng very well. I need someone here to give me a detailled method to make a compression spring. I am a real newcomer, so please detail it for me. I need to make a bunch of springs from 1 1/2" long to 4" long and from 1/2" in od to 1 1/2" od, using vareying thicknesses of piano wire for the spring. Isaac Sarnoff Quote Link to comment Share on other sites More sharing options...
shift1313 Posted July 26, 2017 Share Posted July 26, 2017 Welcome aboard Isaac! Which version of Solidworks are you using? Files are not backwards compatible so a file from 2017 won't open with a feature rich "tree". There are two main methods for making a spring. Sweep along path with a twist or Sweep along helix. The main difference in the end result is the alignment of the profile. When sweeping along path with a twist the profile gets distorted. For the past few versions of Solidworks the Sweep feature has an option called "Circular Profile" that allows you to just draw a helix(found on the curves menu) without having to create the extra plane/sketch for a circular profile spring. I don't have any videos to show of making a spring that are open to the public but here are a few resources. On my site i have a long video detailing the process of cutting threads. Its the same as making a spring you just have to change the profile and do a solid Sweep instead of a Sweep-cut. https://www.solidbox.tv/course/solidworks-cutting-threads/ My site is free to register and no spam to your inbox from the site. The next resource is one of the spring companies i frequently buy from. They not only have a huge catalog of springs but you can configure and download CAD models of the spring at full compression, extension or pick a value in between. https://www.asraymond.com/ lastly one of the other members sent me this document to upload for you. Step by Step Outline for E Z Spring.zip Quote Link to comment Share on other sites More sharing options...
ira Posted July 30, 2017 Author Share Posted July 30, 2017 thank you shift313, the short outline you sent me works perfect for me. Isaac Sarnoff Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted August 28, 2017 Share Posted August 28, 2017 As an alternative you can look here: https://www.youtube.com/results?search_query=solidworks+compression+spring Youtube has a truckload of all sorts of Solidworks tutorials at all levels.. Sometimes you find alternate methods for doing the same thing too. YouTube is a great resource.. Quote Link to comment Share on other sites More sharing options...
