Results 1 to 5 of 5
    Forum Newbie
    Electrical
    AutoCAD 2015
    Jul 2017
    5
    Question Layer State Beginner
    My drawings have multiple layouts with multiple View Ports in each, the drawing has a few Layer States set up (mainly made up of VP freezes). Within each layout all different layer states are used in various view ports.
    Problem is when I have to update a layer state they don't automatically update all the view port using the same layer state. I have to individually click into each view port and restore the state via the layer manager the (there are hundreds of view ports).
    Is there a variable I have to set (my VISRETAIN is set to 1 and would like to keep at 1)?
    How can I make the layer state apply changes to all view ports (if not the whole drawing then layout by layout would help) using the same layer state when updated?
    AutoCAD 2013
    Nov 2011
    5,985
    Welcome to CADTutor Tudors.
    I am not aware of any way to do that within Autocad, short of a custom lisp, as each of the viewports layer properties has been modified internally.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,881
    I have moved your thread to the AutoLISP, Visual LISP & DCL Forum.
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    744
    In the Layer States dialog box if "Apply properties as viewport overrides" is checked the layer state is applied as viewport overrides in current viewport. Why not simply apply the layer state to the Model tab so the layer properties are set in every viewport at once?
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  5. #5
    Forum Newbie
    Electrical
    AutoCAD 2015
    Jul 2017
    5
    "Apply properties as viewport overrides" was checked, and still viewports do not update with updated layer states.
    I have already applied a layer state to model tab for certain view ports in paper, but i still have other layer states to apply in other viewports with in the same paper/layout space.
    Lets just say i have 15 viewports in one layout tab.
    5 VPs use model space layer state A
    5 VPs use paper space layer state B
    5 VPs use paper space layer state C
    Really there is over 50 layouts and multiple drawings, if i could do it within the drawing that would be a huge time saver because layer state names are different per drawing.
  1. Layer State Management
    By sheeptoast in forum AutoCAD Drawing Management & Output
    Last Post: 14th Jun 2014, 01:53 am
  2. Layer color changes with Layer State
    By Crazy J in forum AutoCAD Drawing Management & Output
    Last Post: 15th Feb 2010, 11:18 pm
  3. layer state
    By bstegemann7788 in forum Tutorials & Tips'n'Tricks
    Last Post: 18th Jul 2008, 01:41 am
  4. ssm and layer state
    By VJMP in forum AutoCAD Drawing Management & Output
    Last Post: 19th Sep 2007, 11:26 pm
  5. No option to save layer state in layer manager - Help!
    By cameronsf in forum AutoCAD Drawing Management & Output
    Last Post: 9th Feb 2005, 11:50 am
Tags for this Thread
