Results 1 to 6 of 6
    Full Member
    howitzer's Computer Details
    Windows 7-64 Pro
    8GB
    nVid-something
    Civil
    howitzer's Discipline Details
    Civil Engineering Technician
    Civil
    Civil 3D 2015
    Dec 2012
    Iowa
    36
    Default Survey: One file vs multiple files (x-refs)
    I'm curious what others think and do. (Also posted on Autodesk forum in case you've seen it there.)
    Let's say you have a street project. It's going to be 25 sheets, broken down into various purposes, i.e.: street plan & profile, underground utilities, sidewalk/ramps (required here), and so on. How do you do this?
    1) Do you have a single file with all line work, annotation, and everything, and then 25 layout tabs, controlling each sheet/tab with freezing and thawing by viewport?
    2) Do you have a "base file" that is mostly just line work , then have separate plan sheet files for annotation and other extraneous items with line work x-ref'd in and/or dynamic entities d-link'd in?
    3) Do you do a mix-and-match of both?
    What are the pros and cons of any of these? What have your experiences been?
    I do see benefits AND downsides to both methods, but I tend to do something of a mix-and-match, albeit I lean heavily toward #2. I have done several smallish projects where everything was in a single file and by the time I was done I always regretted doing so. Neither way is perfect by any measure, but in my experience... while I am good at layer manipulation and still believe in layer management over other newer forms of visibility... there always seems to be a point where it becomes too much, and affects speed, both literally in the single file and in the thinking and coordination. To me there is value in keeping the plan files separate and simple.
    I will generally group a bunch of like-sheets in a plan file. One dwg for plan & profile, one for underground utilities, etc. If the project is unusually large and/or complicated, I will even separate out the types of underground utilities.
    I have been doing this for almost three decades now, and I am aware that some of my thinking can be "old school", but I feel that I have a good mix-and match of old school thinking and new school thinking. The old ways aren't always bad, and the new ways aren't always better... though new is often better, to be fair.
    So anyway, what say you?
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Is everything done in-house or do you get files from outside sources for use as backgrounds?
    Drafting is a breeze.
    Full Member
    Windows 7-64 Pro
    8GB
    nVid-something
    Civil
    Civil
    Civil 3D 2015
    Dec 2012
    Iowa
    36
    Quote Originally Posted by RobDraw View Post
    Generally everything is done in-house, except architectural building floor plans. But even those we keep separate and x-ref-attach into the base design file. Even at a previous employer where would often get existing topo from an outside source the procedure was pretty much the same as I do now.
    What is your process, and what affects how or why you do what you do?
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,461
    #1 - no way I'd tie up all that info in a single drawing. Too much to potentially lose with a corrupt drawing.
    Generally speaking, #2. Allows multiple people to work on project at the same time.
    R.K. McSwain
    CAD Panacea | twitter
  5. #5
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,148
    Purely from a management standpoint, it's better to split your work areas. Use xref to bring in the information you need from other drawings, and freeze everything else. When I show an engineer or architect an area that has everything thawed, they don't react well. I'm used to it, they aren't.
    That scheme also helps to split up your annotation. My thinking is, why make things more complicated than they have to be?
    Finally, I agree with McSwain. Even if you have instant backup systems, you lose time getting back to where you were.
    breaking AutoCAD on a regular basis since 1991
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    The others are on track with what I would do. Files basically are split according to trade (users and/or consultants) and are XREF'd into each other for coordination.
    I've thought about, but never implemented, the model/annotation split.
  1. Opening and Inserting Multiple X-refs into Multiple Layout Spaces
    By karrotbear in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Sep 2016, 04:39 am
  2. One .DWG file from Multiple .DWG files
    By vbauer in forum AutoCAD Beginners' Area
    Last Post: 13th May 2011, 06:19 pm
  3. Print Multiple .idw files to one PDF file
    By bdanielson in forum Autodesk Inventor
    Last Post: 15th Oct 2010, 10:24 pm
  4. joining multiple DWG files into one file
    By spoof81 in forum AutoCAD General
    Last Post: 29th Apr 2010, 12:54 pm
  5. Inserting multiple x-refs?
    By anfeardearg in forum AutoCAD General
    Last Post: 11th Oct 2005, 01:34 pm
