Results 1 to 6 of 6
Thread: Wblock on LT
    Super Member
    AutoCAD 2010
    Dec 2010
    1,163
    Default Wblock on LT
    hi
    my friend used to wblock his drawing in order to filter out any garbage,
    he told me that his Autocad LT 2012 is not handling the drawing like my pc (autocad full 2010)
    is there any different of wblock functionality of LT compare to the core Autocad?
    Thanks
    S
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2017
    May 2013
    An Englishman in Belgium
    2,038
    What is it doing differently?
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
    Super Member
    AutoCAD 2010
    Dec 2010
    1,163
    in LT its hardly effects the file size while in the core its 90% discount after the wblock
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2017
    May 2013
    2,038
    To the best of my knowledge there is no difference in how the command works, are the settings the same on both machines (are they both saving to the same Autocad version, both using the same units etc.) and both using the same source drawing.
  5. #5
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    184
    When you use WBLOCK, you get three options..
    - Source: Block, Entire Drawing, or Objects.
    The differance may be there?
  6. #6
    Super Member
    AutoCAD 2010
    Dec 2010
    1,163
    no. i talking only about the Entire Drawing option
  1. wblock
    By metaldan in forum .NET, ObjectARX & VBA
    Last Post: 13th Mar 2012, 06:03 pm
  2. WBlock
    By bracken2 in forum Student Project Questions
    Last Post: 21st Sep 2011, 03:17 pm
  3. Wblock
    By CindyLou in forum AutoCAD Drawing Management & Output
    Last Post: 16th Nov 2007, 06:24 pm
  4. Wblock
    By HAPPY HAMMER in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Nov 2007, 12:52 pm
  5. WBLOCK IN ADT 3.3
    By gguillory in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Feb 2005, 06:15 pm
