Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Junior Member
    AutoCAD 2015
    Nov 2016
    11
    Default LISP | Clean Drawing | Explode and Purge
    Explanation: To clean up consultant drawings I explode everything multiple times, move all objects to 0 layer, change all properties to By Layer (or equivalent), and purge the file. Then I Ctrl+Shift+C to select base point and in my file Ctrl-Shift+V to create a clean block that serves as the base for our drawings.
    Goal: LISP that does all the cleaning! Including:
    1. Explode everything multiple times
    2. Select everything in file and
    layer --> 0
    color -->By Layer
    linetype --> By Layer
    lineweight --> By Layer
    3. Purge everything (to be left with only 0 layer)
    I've found bits and pieces in different posts, but I am hoping to get some more comprehensive help.
    Thank you for your time, in advance!
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    304
    Something like this?
    Code:
    (defun C:BIGBANG ( / )
    ;; First we busrt everything a few times...
    (setq timesexplode 10) ;Change number to suit your needs
    (repeat timesexplode
    (setvar "qaflags" 1)
    (command ".explode" (ssget "_X" ) "")
    (setvar "qaflags" 0)
    ;define allobjects
    (setq allobjects (ssget "_X" ))
    ;; Now set everything by layer...
    (command "_SetByLayer" allobjects "" "Yes" "Yes")
    ;; Set everything to layer 0
    (command "_CHANGE" allobjects "" "Properties" "Layer" "0" "")
    ;; Set current layer 0
    (setvar "CLAYER" "0")
    ;; Purge the drawing
    (command "-Purge" "All" "*" "No")
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    895
    THIS should get you the layer 0 part.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Would running the Overkill command be necessary with these drawings?
    You should purge Regapps first then do a Purge > All.
    I would also suggest running the Audit command and answer Yes to fixing any errors that are found in the database.
  5. #5
    Junior Member
    AutoCAD 2015
    Nov 2016
    11
    Aftertouch -- Thanks, your lisp works great!
    ReMark -- I do not necessarily need overkill; the goal is just to rid the cad of any consultant blocks, layers, styles, etc. And I will look into adding the audit command, thanks for the suggestion!
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Overkill rids drawings of duplicate and overlapping lines, arcs and polylines. Have you ever tested one of the drawings to see if such entities exist in the drawings you are receiving?
  7. #7
    Senior Member
    Civil
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    304
    Made a few changes, added in ReMarks suggestions.
    Code:
    ;; Set undo begin and silence program
    (setvar "cmdecho" 0)
    (command "UNDO" "BEGIN")
    (setvar "QAFLAGS" 1)
    (setvar "QAFLAGS" 0)
    ;define allobjects
    (command "_SETBYLAYER" allobjects "" "Yes" "Yes")
    ;; Audit the drawing
    (command "_AUDIT" "Yes")
    (command "_PURGE" "Regapps" "*" "No")
    (command "_PURGE" "All" "*" "No")
    ;; Remove duplicates for better performance
    (command "-OVERKILL" allobjects "" "Ignore" "None" "Done")
    ;; Tell use the program is finished
    (princ "\n\nJobs done.")
    ;; Set undo end and wake up program
    (command "UNDO" "END")
    (setvar "cmdecho" 1)
    Super Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    895
    You also might add in something like this to unlock all layers and make sure the blocks can actually be exploded.
    Code:
      (setq ad (vla-get-activedocument (vlax-get-acad-object)))
      (vlax-for b (vla-get-blocks ad) (vla-put-explodable b :vlax-true))
      (vlax-for l (vla-get-layers ad) (vla-put-lock b :vlax-false))
    Also don't forget to localize your variables: ( / ALLOBJECTS TIMESEXPLODE)
  9. #9
    Full Member
    AutoCAD 2017
    Oct 2013
    89
    I can't really find a thread that's exactly what i'm after. I have a code that works beautifully for finding a block by its name, then using the "BURST" command on it. I would like to add more block names to it "ICEBRIDGEDYN" is the one i want to add now. I'm very new to coding. Can anyone show me the code that would look for "ICE BRIDGES" and "ICEBRIDGEDYN"?
    Code:
    (vl-load-com)
    (defun c:BIB ( / e ss objs blk) ; by name
      (setq e "ICE BRIDGES" ; (getstring T "ICE BRIDGES")
            objs (ssadd))
      (if (setq ss (ssget "_X" '((0 . "INSERT"))))
            (setq name (strcase (vla-get-effectivename (vlax-ename->vla-object (setq blk (ssname ss (setq i (1- i))))))))
            (if (wcmatch name (strcase e))
              (ssadd blk objs)))
        (if (> (sslength objs) 0)
    	(sssetfirst nil objs)
    	(c:burst)))))
    can anyone help me out?
  10. #10
    Super Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    895
    Code:
    (setq e "ICE BRIDGES,ICEBRIDGEDYN")
  1. Replies: 7
    Last Post: 7th Mar 2014, 05:02 pm
  2. How do i can explode all blocks in drawing with lisp file??
    By hosyn in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Sep 2013, 10:50 am
  3. Clean up drawing
    By M76 in forum AutoCAD Drawing Management & Output
    Last Post: 26th Feb 2010, 01:03 pm
  4. Drawing Clean Up Automation
    By Cad_Jockeys in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jul 2008, 10:49 pm
  5. explode and purge files
    By fbby in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jun 2008, 04:49 pm
Tags for this Thread
