Results 1 to 8 of 8
    Full Member
    Kevin Malone's Computer Details
    Windows 7
    AutoCAD 2010
    Apr 2015
    Bosnia and Herzegovina
    29
    Default Creating custom coordinate system (with datum parameters TOWGS)
    I'm tying to create custom Coordinate System in C3D 2012 with datum parameters (Dx, Dy, Dz, Rx, Ry, Rz and scale), but during the creation process (thru MAPCSCREATE function) I don't get anywhere to input this values. As you can see on screenshot, TOWGS parameters are all "0".
    Only way to form some kind of datum with parameters is creating Geodetic Transformation, but I can't link/import that in my CS definition
    I would appreciate any help
    Junior Member
    Pointdump's Computer Details
    Windows 7 Pro
    Construction
    Pointdump's Discipline Details
    Carpenter
    Construction
    Civil 3D 2014
    Oct 2013
    Las Vegas, Nevada
    20
    Kevin,
    A little more information please. In what coordinate system are you starting with and what and why are you changing it to?
    Dave
    Full Member
    Windows 7
    AutoCAD 2010
    Apr 2015
    29
    Hello David,
    Thank you for replying. I'm not sure I understand your question. Why would I have to start from something, and why would I change it to something?
    I'm expecting to create new Coordinate System by defining:
    1) Ellipsoid (Bessel 1841)
    2) Datum (Dx, Dy, Dz, Rx, Ry, Rz, scale)
    3) Projection (Transverse Mercator:central meridian: 18ยบ , false easting: 6500000, scale reduction: 0.9999)
    I'm able to define all, except Datum parametres.
    My projection from QGIS (what I'm trying to accomplish in C3D):
    Code:
    +proj=tmerc +lat_0=0 +lon_0=18 +k=0.9999 +x_0=6500000 +y_0=0 +ellps=bessel +towgs84=582.423611,193.160015,418.65025,5.94041362,-0.17569994,-12.99256834,3.46772346
      +units=m
    Junior Member
    Windows 7 Pro
    Construction
    Carpenter
    Construction
    Civil 3D 2014
    Oct 2013
    Las Vegas, Nevada
    20
    Kevin,
    "Why would I have to start from something, and why would I change it to something?"
    I guess what I'm asking is for specifics on what you are doing and why you need to create a unique coordinate system. Are you incorporating GIS data in your drawing? Survey points? To whom are you passing your drawing to, and will they be able to re-create your unique coordinate system?
    C3D has a fairly rich library of Ellipsoids, Datums, and Projections. I'd find a coordinate system close to what you want and duplicate, then edit.
    Dave
  5. #5
    Full Member
    Windows 7
    AutoCAD 2010
    Apr 2015
    29
    Dave,
    I'm surveyor and I'm currently working on GIS, so yes - I do work with GIS data and survey points. Unfortunately none of current CS's in C3D library does not fit my needs entirely. Closest CS would be EPSG:31276 MGI\BALKANS ZONE 6. This is CS with "global" parameters, and they differ from my local parameters (0.7-2.3m on control points). Local parameters are calculated for city area.
    I have earlier tried to duplicate and then edit duplicated CS, but again - I can only edit ellipsoid and projection.
  6. #6
    Junior Member
    Windows 7 Pro
    Construction
    Carpenter
    Construction
    Civil 3D 2014
    Oct 2013
    Las Vegas, Nevada
    20
    Kevin,
    "Local parameters are calculated for city area."
    OK, I think I see now. You want ground distances and Geodetic North to match AutoCAD "top of page", right?
    "I'm able to define all, except Datum parametres."
    It's amazing how easy it is to do that in the free QGIS, and so unfathomable in expensive C3D. Unfortunately, I don't know how to do that either. But maybe a Custom Low Distortion Projection would serve you. You can keep the WGS84 Datum (or whatever CS you use in your GPS receiver) and just define a new Origin Longitude, Origin Latitude, False Easting, False Northing, and Scale Reduction. For scale you'd need the Combined Factor, Scale Factor X Elevation Factor.
    Dave
  7. #7
    Full Member
    Windows 7
    AutoCAD 2010
    Apr 2015
    29
    Dave,
    Thank you for clarification. Now, at least I know it's not possible (still can't understand why).
  8. #8
    Junior Member
    Windows 7 Pro
    Construction
    Carpenter
    Construction
    Civil 3D 2014
    Oct 2013
    Las Vegas, Nevada
    20
    Kevin,
    OK, I did some digging, because I sure didn't know how to create a new Datum Definition with a 7-Parameter Transformation. I figured out that it's a 2-step process. But it seems doable.
    Here's what the Help Section says:
    1. Use <<<_MAPSCREATE DATUM>>> to name your new Datum and select an Ellipsoid.
    2. Use <<<_MAPSCREATE GEO>>> to start the assistant to define the geodetic transformation.
    Dave
  1. Create a custom UCS (User Coordinate System) in AutoCAD
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 10th Dec 2012, 05:30 am
  2. Codes missing when creating surface from datum of corridor
    By Mark_CV3D in forum Civil 3D & LDD
    Last Post: 16th Nov 2012, 12:54 pm
  3. How do I know which coordinate system to use?
    By salmonrose in forum AutoCAD Beginners' Area
    Last Post: 31st Jul 2010, 12:23 am
  4. coordinate system keeps shifting
    By gib65 in forum AutoCAD Beginners' Area
    Last Post: 1st Dec 2007, 12:05 am
  5. About coordinate system
    By gnotnoel in forum AutoCAD Beginners' Area
    Last Post: 13th Jun 2006, 08:33 pm
Tags for this Thread
