Results 1 to 3 of 3
    Senior Member jonathann3891's Avatar
    jonathann3891's Computer Details
    Window 7 64 Bit
    Structural
    jonathann3891's Discipline Details
    Oil & Gas
    Structural
    AutoCAD 2012
    Dec 2008
    Houston, TX
    126
    Default Dim Extension Lines not Plotting
    Whats up everybody!
    I have a weird problem that I cannot figure out.
    Some of my dimension extension lines and leaders are not plotting, but are showing up in the print preview and PDF's.
    Seems to only be a problem when plotting 11x17.
    I've attached proof!
    Jonathan Norton
    Blog | Linkedin
    Senior Member
    AutoCAD 2017
    Jun 2013
    137
    Export to PDF then print the PDF?
    Window 7 64 Bit
    Structural
    Oil & Gas
    Structural
    AutoCAD 2012
    Dec 2008
    Houston, TX
    126
    It turned out to be an issue with the printer itself.
    Jonathan Norton
    Blog | Linkedin
  1. Diameter Extension lines
    By Mase123y in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th May 2013, 05:53 pm
  2. autosnap to dimension extension lines
    By louA in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Sep 2012, 12:29 pm
  3. getting dimension closer to extension lines
    By emacrisema in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Apr 2009, 09:00 pm
  4. How do you scale Dimension Extension Lines?
    By savydrake85 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Sep 2008, 09:49 pm
  5. put arrows outside extension lines?
    By nicnicman in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Apr 2008, 09:49 pm
