Results 1 to 6 of 6
    Forum Newbie
    Civil
    Civil 3D 2017
    Aug 2017
    1
    Default Civil 3D surface troubles - HALP!
    The situation: I'm working on a project which is a 16 lot subdivision. I currently have my existing and proposed grades as surfaces, and I need to add the excavation for the proposed houses into the proposed surface so that we can run an accurate cut/fill analysis.
    What I've tried: breaklines, feature lines turned into breaklines, separate surfaces for each house to then be pasted into the proposed surface, adding points, wall breaklines
    What's worked well: None of it. It's possible that I'm simply going wrong with one or two small details in the process - my skill level is hardly proficient in Civil 3D surface modeling, yet is the most advanced in the office (the boss last did surfaces in Land Desktop).
    I'm now on day three of trying to get this thing to work, having been told repeatedly to try the same handful of things, which invariably haven't worked. I've had good luck finding information on CadTutor, so I'm now turning to these forums.
    Thank you.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,877
    I moved your thread to the Civil 3D & LDD Forum.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,153
    Have you tried defining the edges of the excavation as a curb (or similar feature)? You can define the upper and lower elevations. I don't have Civil 3D here, so I can't test my theory.
    breaking AutoCAD on a regular basis since 1991
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,017
    The problem with house lots is generally that at the edges you often need a vertical wall, as the batter can not proceed into the adjoining property.
    You need to check your grading and use a almost vertical batter, if the house slab taking AUS as an example has the garage with a step down versus the house area, in this case a 1mm offset will work giving you the vertical you need. Its gets interesting in the corner of the two levels.
    As mentioned you may need to create a boundary line that has this 1mm in it at the corners then batter each edge with a different slope. I played around with this problem a lot of years ago and there is no quick answer. You may need to add a "LINE" with the correct Z to the surface model to get the verticals working. As its house excavation you need to get as close as possible to the desired shape.
    I did a huge job in area size for a Chinese project 2kmx2km and just had to keep adding the new road feature shapes 1 at a time ad checking that the surface was correct shape, including curves that had to be approximated by straights. It had like 15 surfaces to get to the final shape.
  5. #5
    Windows 10
    Architectural
    Civil Drafter
    Architectural
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,153
    The trouble with defining holes in Civil 3D, as I recall, is that it won't process vertical surfaces. That whole dividing by zero thing, I guess.
    Have you tried this? Start with the breakline for the upper edge of the hole. Offset that breakline inward by a tiny amount, such as .001. Change the elevation of that inner breakline to the bottom of the hole. Once you add that breakline to your surface, you have a set of almost-but-not-quite vertical faces to represent the sides of the hole. Your cut/fill totals will be wrong but only by a tiny amount. If you're a real stickler, you can calculate the difference and adjust your totals.
    For a split-level house, use two or more extra breaklines. Just make sure they don't overlap.
  6. #6
    Senior Member sandiegophil's Avatar
    sandiegophil's Computer Details
    Windows 10 64bit
    HP z640
    E5-2609 v4 1.7GHz
    64gb
    nvidia m3000
    ssd
    2-Z27s
    Civil
    sandiegophil's Discipline Details
    CAD Manager - County of San Diego DPW
    Civil
    Civil 3D 2018
    Feb 2009
    San Diego, CA
    266
    regarding CyberAngel's comment:
    that's 100% true about the vertical
    I will suggest a possible solution that I've used in the past.
    If you use a generic linkwidthandslope and set the slope to 50000 or -50000, something just ridiculous, it gives you a near vertical "wall"
    you can also type in the word "vertical" in the slope/grade field but you will need a tiny horizontal piece at the end end to finish the surface.
    I hope i stated this in a sensible way...
  1. create cut fill surface from excisting surface in Civil 3d
    By smileyours in forum Civil 3D & LDD
    Last Post: 1st Mar 2013, 09:26 pm
  2. Replies: 3
    Last Post: 29th Oct 2012, 01:37 pm
  3. Civil 3D Tin Surface into Inventor
    By Furie in forum Autodesk Inventor
    Last Post: 12th Mar 2012, 04:30 pm
  4. Change Comparison surface on a Volume surface Civil 3D
    By cadjunkee in forum Civil 3D & LDD
    Last Post: 30th Apr 2011, 08:03 pm
  5. Civil 3D Surface - Max?
    By spittle in forum 3D Modelling
    Last Post: 24th Sep 2008, 03:31 pm
