Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2007
    Oct 2016
    8
    Default LayersPropertiesManager
    I am using Acad2007. I am trying to use Layers Properties Manager and I can't get color, line type, etc to stick in layers. I have purged, and audited the drawing to no avail
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    I suspect you somehow managed to override these settings. Best bet is to attach a copy of your drawing (a .dwg file; not an image file) to your next post. Someone here will take a look at it and get back to you.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    I moved your thread to the AutoCAD Drawing Management & Output Forum.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,211
    Are these layers in an xref, perchance? What is the setting for VISRETAIN?
    breaking AutoCAD on a regular basis since 1991
  5. #5
    Forum Newbie
    AutoCAD 2007
    Oct 2016
    8
    No xrefs setting is 1
  6. #6
    Forum Newbie
    AutoCAD 2007
    Oct 2016
    8
    Default added dwg file
    I tried to add 1strrft.dwg lets see if it worked
  7. #7
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Well, I am a little confused. What do you mean by "stick in layers"? Do you mean you can't save your changes to the layer properties? How are you changing the layer properties?
    Do you mean you can't get the objects to take on the layer properties?
    I looked at the drawing. This is what I found upon opening.
    1. All layers are assigned the same color.
    2. The objects that do have an object color property of By Layer, are the layer color, except that one cannot tell what layer they are on by looking at the color because the layers are all the same color.
    3. Object properties override layer colors - an object with a property set to something other than By Layer will not assume the layer property.
    I did change the layer color properties. They stayed. I closed, and re-opened and they were still there, so I can only assume (for now) that your problem is number three above.
    By the way. Here is a little tip that almost nobody anywhere near a school of architecture knows. Stud spacing begins with the corner studs always dead on the corner like you have them, then the first field stud is set to 15 1/4" in from the outside face of the corner stud to the same side face of the first field stud so its center line will be 16" from the outside corner of the wall. However, you have your first stud set 16" face to face, which make them all 3/4" too far from the corner. Framing carpenters expect the center line of the first field stud to be 16" in from the corner or end of a wall, at least on one end of the wall. With them set 3/4" off the framers will be just nicking the edge of the studs with their nails when they hang sheathing on them. Also, the first full sheet of sheathing will be 3/4" too short to reach the last stud center line it is to be nailed to.
    Not to worry, the framers will ignore any drawing and set the studs spaced the way they want them anyway.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
