Results 1 to 10 of 10
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,117
    Question Hide or Isolate Objects by Viewport?
    Hello all, is there still not a way to use the Isolate or Hide Objects tool in AutoCAD per each viewport? If I have multiple viewports of the same 3D or AEC Objects from modelspace, I'd like for each Viewport to turn off or on certain objects.
    One note: Layer Management cannot do this to the best of my knowledge. Also, my question refers more to AEC Objects from the vertical products, but is still generally asked for normal solids.
    I tried VIEWBASE as an option but it only sees normal solids and not AEC Objects.
    Thanks in advance!
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,208
    As far as I know, you still have to put objects on different layers to control their visibility permanently. Can you imagine the complexity of tracking visibility for each object and each viewport?
    breaking AutoCAD on a regular basis since 1991
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,117
    Quote Originally Posted by CyberAngel View Post
    I can certainly imagine. Revit does it, and it is so simple and easy yet so very effective, and oh how I wish AutoCAD could integrate this almost necessary visibility process.
    -TZ
  5. #5
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,117
    Let me reiterate that I'm wanting to hide or isolate objects not layers. For instance, a line that is present in one viewport and hidden in another viewport, with no connection to the layer visibility at all.
    -TZ
  6. #6
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    697
    It is AutoCAD, not Revit, TZ . If we were able to that in AutoCAD what the heck do you need Revit for? ;-)
    If you want 'Objects' to turn invisible in viewports, then place them together in a xref and turn these xref layers off..
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  7. #7
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,117
    All I'm asking if objects can be individually hidden or isolated by Viewport. These commands exist in AutoCAD but this is a drawing-wide command, and we're using AutoCAD MEP on a project which utilizes AEC Objects (<---- "Objects" not Layers, yes in AutoCAD, imagine that). I'm sure there are many other CAD programs besides Revit that can hide objects by View or Viewport.
    All I'm asking if this is possible yet in AutoCAD. As of right now, the answer is no, unless someone knows a workaround or a solution. I'm just asking for a solution in AutoCAD, not a flame war. Thanks in advance.
    -TZ
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,592
    Have you tried wipeout ? It can be on 1 layer. Just did a quick test model and layout combos 3 wipeouts, but was not a 3d object.
  9. #9
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,117
    Quote Originally Posted by BIGAL View Post
    Thanks Big Al, definitely a workable alternative but not one I'm willing to implement. I'm using isometric views a lot in this scenario. Thanks for your suggestion, always appreciated!
    -TZ
  10. #10
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,592
    I was a bit worried about 3d views. Creating multiple wipeouts as screens very interesting.
    Another thought Pface it must be a plane but you can not see through if you use hide, supports 3dpoints in its creation I know as used it for building pitched roofs and 100% works can not see through roof. All points created in world UCS.
  1. Isolate Objects in Viewport
    By Bthecory in forum AutoCAD General
    Last Post: 30th Apr 2016, 10:02 am
  2. Is there a way to hide objects behind a viewport?
    By Badgered in forum AutoCAD Drawing Management & Output
    Last Post: 10th Feb 2011, 03:37 am
  3. Double "Hide/isolate objects" is it possible?
    By marmo in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jul 2010, 04:45 pm
  4. Isolate OBJECTS per Viewport
    By Jadeous in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Nov 2009, 04:45 pm
  5. Isolate Objects in Viewport Command
    Last Post: 12th Mar 2009, 09:20 pm
