Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Full Member
    AutoCAD 2007
    Jul 2014
    79
    Default Printing service that recognizes CAD formats
    Hello,
    I design automatic tooling for micro-parts, and 95 percent of my work I am able to print out myself using a standard 8.5 X 11 size printer. However there is that pesky 5 percent that will not fit on standard size paper and requires either legal 8.5 X 17, or ledger 11 X 17 printing, at printing 1:1. 5 percent does not justify my purchasing an oversize printer or plotter. That being said, would anyone here know of a printing service that recognizes CAD formats, so I can print out the few that I need one to one. The formats I use are dxf, dwg, sldprt, sldasm, 3dm.
    Thank you,
    Chubarka
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GTX 650 (H)
    520 gb SSD 0/ 1TB 1 (W) 256 GB SSD (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2019
    Sep 2002
    Winston-Salem, NC - USA
    5,678
    Why would PDF and or other vector (dwf) formats not work? Are you printing sheets? 11x17 inkjet printers are not that expensive, depending on where you are located in the world. I saw one on Amazon for $110.
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
    Full Member
    AutoCAD 2007
    Jul 2014
    79
    Thanks for your response. That is a pretty low price, I have never seen anything approach that one. I have had printings done using pdf in the past, I believe they were done by printers using the
    percentage technique to increase or decrease, they never did approach real accuracy like that I get by doing it 1:1 in AutoCAD. Since I posted this query, I have been in touch with a Blueprint
    company that boasts real good accuracy, we'll find out real quick. I thank you for your response again.
    Chubarka
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2019
    Sep 2002
    5,678
    OK, I am confused. AutoCAD has it's own PDF printer installed, well current versions do. I understand that a PDF printed from one driver can differ from another put once it's on paper it should look the same. Is someone scaling off your drawings? Isn't that usually a "no-no"? Sorry for my confusion
  5. #5
    Full Member
    AutoCAD 2007
    Jul 2014
    79
    When I am able to print out from AutoCAD, that means that my printer can handle the size, I have no problems whatsoever with accuracy whether I print pdf or dxf at 1 : 1. However because a printer recognizes pdf , it is not necessarily compatible with AutoCAD, is only a guess on my part. For example I just today had a print for a progressive die printed out at a large franchise printing service. The length of the die itself is 13". It came out 13.130". When I gave it to the Printer, I was told to save it as a pdf. As sure as you are a foot high, I will get a complaint from the Client.
    Thank you again,
    Chubarka
  6. #6
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2019
    Sep 2002
    5,678
    Huh, could you share a design to test print?
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    The problem with 13=13.13 is simple they or you have done a FIT to the sheet rather than use true size at a nominated plot scale in that it would have been 1=1, re 11x17 just make your pdf that size do not use any scale factor say 11x8 rescale to 11x17 thats asking for problems.
    There shoud be only very tiny errors in the printing maybe 1mm at most not 1/8" we have measured A1 24x36 plots and they are like on the other side of the ruler measured indicator mark thats like 0.25mm.
  8. #8
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    There is no good reason why, even using AutoCAD 2007, you cannot produce a suitably accurate PDF file that when printed on 11x17 paper, and checked, isn't accurate. We do it all the time printing to three printers manufactured by three different companies (HP, Kyocera and Cannon) and using different versions of AutoCAD.
    Please attach a sample copy of a .dwg or .dxf file for testing purposes to your next post.
  9. #9
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    There are several printers on Amazon under $150 that will do 11 x 17 or larger.
    Brother
    Canon
    I have that Canon at home.
    FedEx office should handle CAD file types, is there one close to you? You should be able to take a USB in and print it yourself.
  10. #10
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2019
    Sep 2002
    5,678
    I agree with Bigal and Remark, no reason at all that the plots should not be spot on or at least very close. Again one should NEVER scale off a drawing. That's what dimensions are for
  1. Replies: 12
    Last Post: 20th Apr 2012, 03:24 pm
  2. Sheet Formats
    By spittle in forum SolidWorks
    Last Post: 26th Dec 2008, 03:14 pm
  3. How autolisp recognizes table cells?
    By oji_d in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Aug 2007, 06:02 am
  4. Converting dwg to different CAD formats?
    By earthtodan in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jul 2007, 10:21 pm
  5. changing formats
    By KadieMills in forum AutoCAD General
    Last Post: 5th Jan 2007, 04:47 pm
