Results 1 to 2 of 2
    Forum Newbie
    Civil
    Civil 3D 2017
    May 2009
    4
    Default Replace individual block
    I am sure this question has been ask in the past. I have a dwg with various blocks that I want to replace individually with a selected block. I know of "Blockreplace" but that replace all block with the same properties. There is a lisp routine bre.lsp but it does not want to work in AutoCAD 2017. Any sugestions
    AutoCAD 2013
    Nov 2011
    6,056
    How about renaming the blocks you want to replace, then using BLOCKREPLACE to change those only?
  1. Toggle select block or individual elements in the block?
    By samifox in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jul 2017, 07:15 am
  2. Replies: 0
    Last Post: 15th Oct 2016, 06:39 am
  3. Sort individual rev blocks by date and map attributes to new title block
    By Da Ballz in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Jul 2015, 06:42 am
  4. Change Attributes in individual drawing block by picking it.
    By muck in forum .NET, ObjectARX & VBA
    Last Post: 17th Sep 2014, 04:10 am
  5. Size variation between blocks Using replace block with another block
    By narendra in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Jul 2014, 12:32 pm
