Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Default MLeader LSP not working
    Hello,
    My manager made this LSP file for me and it doesn't work and we are both not sure why. Seems correct to me.
    How it works: Creates the E-Anno-Note layer, otherwise makes it current, then creates an MLeader (to avoid creating leaders on incorrect layers).
    Code:
    (DEFUN C:NN ()
      (setvar "cmdecho" 0)
      (if (not (tblsearch "layer" "E-Anno-Note"))
        (command "-layer" "n" "E-Anno-Note" "c" "2" "E-Anno-Note" ""))
      (command "-layer" "m" "E-Anno-Note")
      (COMMAND "mleader")
    Thanks!
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,249
    Hi,
    Need to add double quotes.
    Code:
    (command "-layer" "m" "E-Anno-Note" "")
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Quote Originally Posted by Tharwat View Post
    Hi,
    Code:
    Code:
    (DEFUN C:mm ()
      (COMMAND "mleader" "")
    Still doesn't work when I run this...
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,249
    Quote Originally Posted by ryankevin15 View Post
    You have omitted one bracket before the command call.
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    The -layer N is new, M is make new and make current, so does two steps.
    So a slight variation
    Code:
        (command "-layer" "m" "E-Anno-Note" "c" "2" "E-Anno-Note" "")
        (command "-layer" "s" "E-Anno-Note" "")
    also
    Code:
        (command "-layer" "m" "E-Anno-Note" "c" "2" "E-Anno-Note" ""))
        (setvar 'clayer "E-Anno-Note")
  6. #6
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Thanks for the help. This works now.
    Could I make it also adjust the settings of the MLeader before it is drawn so that it will make the right alignment in the middle of the bottom row of text (this is a standard CAD thing that doesn't seem to be the default).
    Thanks in advance.
  7. #7
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    900
    Thanks in advance.
    You could add something like this to the code:
    Code:
    (if (setq e (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE"))
      (progn (setq o (vlax-ename->vla-object
    		   (cdr (assoc -1 (dictsearch (cdr (assoc -1 e)) (getvar 'cmleaderstyle))))
    	 (vla-put-textleftattachmenttype o 5)
    	 (vla-put-textrightattachmenttype o 5)
  8. #8
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Anyone know of any way I can import an MLeader style right before it starts drawing the MLeader?
  9. #9
    Super Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    900
    Make a template and insert it if the mleaderstyle does not exist.
  10. #10
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Quote Originally Posted by ronjonp View Post
    Code:
    I will try this with my manager and see if it works. Thanks!
  1. Set MLeader to Existing MLeader Style via LISP
    By parkerdepriest in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Sep 2017, 09:13 am
  2. Select MLeader by Mleader style
    By pmayer in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Apr 2017, 06:56 pm
  3. Combining two LISP Routines - Leader to Mleader and Mleader Rotate
    By Cylis0509 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jan 2016, 09:12 pm
  4. Mleader ;;; vla-put-???
    By Lee Roy in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Aug 2011, 05:56 pm
  5. Mleader
    By au-s in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Apr 2009, 12:39 pm
Tags for this Thread
