Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    I was able to adjust the leader in the style, but will this code locate the style on my computer or how does that work?
  2. #12
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    952
    Quote Originally Posted by ryankevin15 View Post
    It just changes the current mleader style ( which might actually be bad practice ) ... I would check if the style exists and set it current, else import ( or create with code ) and set current.
  3. #13
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Here is my updated code. Can anyone add some code so that it will import the MLeaderStyle before making the MLeader? Our style is called "Ascent"
    Code:
    (DEFUN C:mm ()
      (setvar "cmdecho" 0)
      (if (not (tblsearch "layer" "E-Anno-Note"))
        (command "-layer" "n" "E-Anno-Note" "c" "2" "E-Anno-Note" ""))
      (command "-layer" "m" "E-Anno-Note" "")
      (command "-layer" "c" "2" "E-Anno-Note" "")
      (command "-layer" "ps" "style_1" "E-Anno-Note" "")
      (COMMAND "mleader")
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Actually, it looks like we need to create this MLeader style every time and set it to current if it doesn't exist...
  1. Set MLeader to Existing MLeader Style via LISP
    By parkerdepriest in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Sep 2017, 09:13 am
  2. Select MLeader by Mleader style
    By pmayer in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Apr 2017, 06:56 pm
  3. Combining two LISP Routines - Leader to Mleader and Mleader Rotate
    By Cylis0509 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jan 2016, 09:12 pm
  4. Mleader ;;; vla-put-???
    By Lee Roy in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Aug 2011, 05:56 pm
  5. Mleader
    By au-s in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Apr 2009, 12:39 pm
Tags for this Thread
