Results 1 to 7 of 7
    Super Member wimal's Avatar
    Construction
    wimal's Discipline Details
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    511
    Default How to load .atc files
    I have a tool palet instollation file with images . the file format type is .atc
    How can I import tool palet with this file. ( The uploading of this file not allowed by cadtutor system.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    From what I can find, *.atc files are tool palette definition files. AutoCad creates them when a new tool palette is created by the user. The *.atc file is the result, not the cause. One cannot just open or import a random *.atc file.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    511
    Quote Originally Posted by Dana W View Post
    Thanks you very much.
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,163
    If you need to transfer palettes between computers, then you need to export and then import using the palette customisation dialogue box this uses a file with the extension *.xtp as Dana W has pointed out the *.atc files are Autocad system files.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  5. #5
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    511
    Quote Originally Posted by steven-g View Post
    if you need to transfer palettes between computers, then you need to export and then import using the palette customisation dialogue box this uses a file with the extension *.xtp as dana w has pointed out the *.atc files are autocad system files.
    i got it. Thanks you also.
  6. #6
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    Just add the folder location to Options>Files>Tool Palletes File Locations. If not from the same AutoCAD Version, they may not work correctly.
  7. #7
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    511
    Quote Originally Posted by SLW210 View Post
    Thanks it is a good idea.
  1. Cad file that load lisp files
    By wimal in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th May 2014, 09:43 am
  2. Autolisp Files won't Load
    By nod684 in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Sep 2013, 03:56 am
  3. How to auto load LISP files?
    By azman in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Aug 2013, 02:40 pm
  4. Cad 2010 dcl files cannot load
    Last Post: 24th Apr 2013, 11:27 am
  5. LISP (or other) to load custom .pgp files (acad.pgp)
    By walton10 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th May 2010, 02:15 pm
