+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Senior Member
    Discipline
    Construction
    wimal's Discipline Details
    Occupation
    cadoperator
    Discipline
    Construction
    Using
    AutoCAD 2016
    Join Date
    Oct 2011
    Location
    sri lanka
    Posts
    423
    Default How to load .atc files
    I have a tool palet instollation file with images . the file format type is .atc
    How can I import tool palet with this file. ( The uploading of this file not allowed by cadtutor system.
  2. #2
    Forum Deity Dana W's Avatar
    Computer Details
    Dana W's Computer Details
    Operating System:
    Windows 8 64 bit
    Computer:
    Dell XPS ONE 2710
    Motherboard:
    Dunno
    CPU:
    Intel I-5 3330S @ 2.7 Ghz
    RAM:
    6 Gb
    Graphics:
    On board barely adequate
    Primary Storage:
    1 Terrabyte
    Secondary Storage:
    1 Terrabyte external
    Monitor:
    All in one 27" touch & pen
    Discipline
    Construction
    Dana W's Discipline Details
    Occupation
    Architectural Millwork Designer/Draftsman
    Discipline
    Construction
    Details
    Custom commercial millwork.
    Using
    AutoCAD LT 2018
    Join Date
    Feb 2010
    Location
    Oviedo, Florida
    Posts
    4,727
    Default
    From what I can find, *.atc files are tool palette definition files. AutoCad creates them when a new tool palette is created by the user. The *.atc file is the result, not the cause. One cannot just open or import a random *.atc file.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  3. #3
    Senior Member
    Discipline
    Construction
    Occupation
    cadoperator
    Discipline
    Construction
    Using
    AutoCAD 2016
    Join Date
    Oct 2011
    Location
    sri lanka
    Posts
    423
    Default
    Quote Originally Posted by Dana W View Post
    Thanks you very much.
  4. #4
    Forum Deity steven-g's Avatar
    Computer Details
    steven-g's Computer Details
    Operating System:
    Win 7
    Discipline
    Construction
    steven-g's Discipline Details
    Occupation
    Draughtsman
    Discipline
    Construction
    Details
    I work in the estimating department of a large building contractor.
    Using
    AutoCAD 2018
    Join Date
    May 2013
    Location
    An Englishman in Belgium
    Posts
    2,087
    Default
    If you need to transfer palettes between computers, then you need to export and then import using the palette customisation dialogue box this uses a file with the extension *.xtp as Dana W has pointed out the *.atc files are Autocad system files.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  5. #5
    Senior Member
    Discipline
    Construction
    Occupation
    cadoperator
    Discipline
    Construction
    Using
    AutoCAD 2016
    Join Date
    Oct 2011
    Location
    sri lanka
    Posts
    423
    Default
    Quote Originally Posted by steven-g View Post
    if you need to transfer palettes between computers, then you need to export and then import using the palette customisation dialogue box this uses a file with the extension *.xtp as dana w has pointed out the *.atc files are autocad system files.
    i got it. Thanks you also.
  6. #6
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO 64-bit
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    Pentium(R) i5 4570 @ 3.2GHz
    RAM:
    8 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2018
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    11,883
    Default
    Just add the folder location to Options>Files>Tool Palletes File Locations. If not from the same AutoCAD Version, they may not work correctly.
  7. #7
    Senior Member
    Discipline
    Construction
    Occupation
    cadoperator
    Discipline
    Construction
    Using
    AutoCAD 2016
    Join Date
    Oct 2011
    Location
    sri lanka
    Posts
    423
    Default
    Quote Originally Posted by SLW210 View Post
    Thanks it is a good idea.
Similar Threads
  1. Cad file that load lisp files
    By wimal in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th May 2014, 09:43 am
  2. Autolisp Files won't Load
    By nod684 in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Sep 2013, 03:56 am
  3. How to auto load LISP files?
    By azman in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Aug 2013, 02:40 pm
  4. Cad 2010 dcl files cannot load
    Last Post: 24th Apr 2013, 11:27 am
  5. LISP (or other) to load custom .pgp files (acad.pgp)
    By walton10 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th May 2010, 02:15 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
