Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2017
    Aug 2017
    2
    Default Export to Adobe Plotting Incorrectly
    Good morning,
    I am having some challenges with plotting from CAD to Adobe then printing. When I export from CAD to 'AutoCAD PDF (General Documentation).pc3' it exports to a PDF in Adobe. When I open the Adobe file, all layers and lineweights are displayed correctly. However, when I plot, certain items appear to go missing. What is weird is that it is not all items within a lineweight - only portions of the line will go missing (see pieces of road and contours will not plot). I cannot find anything corrupt with the AutoCAD file and there isn't anything standing out in Adobe either. I am not sure if this is an Adobe-specific problem or if it is related to AutoCAD. I have attached the CAD file as well as the PDF file. If anyone has any suggestions, that would be appreciated!
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Have you tried with the "dwg to pdf" and compared result. Have used it and cutepdf with no problems.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,147
    The drawing posted had parts of the contour lines missing, so the pdf was entirely correct.
    Forum Newbie
    AutoCAD 2017
    Aug 2017
    2
    Quote Originally Posted by BIGAL View Post
    Hi Bigal,
    Thank you for taking a look at my issue. I have used CutePDF before but the quality of the drawing is not as good as when using the General Documentation. I have used the same export process for other drawings and it appears fine I am starting to wonder if it is more of an Adobe problem than an AutoCAD problem since it exports OK and appears on the screen correct.
  5. #5
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Everything I saw in the drawing came out on the pdf too. I also used dwg to pdf.pc3, and monochrome.ctb. I went through the drawing and replaced the shx fonts with Arial. I also avoided using any commands with the word export in them. Since the 2016 version, I've found no need for third party pdf programs.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  1. Image Plotting Incorrectly
    By ScribbleJ in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th May 2013, 07:49 pm
  2. Replies: 10
    Last Post: 9th Jan 2013, 01:42 am
  3. Large Custom Adobe PDF Size Not Plotting
    By pt_keegan in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jan 2012, 01:48 pm
  4. Adobe PDFmaker (Batch Plotting) vs Autocad 2011
    By ILoveMadoka in forum AutoCAD Drawing Management & Output
    Last Post: 5th Jul 2011, 07:55 pm
  5. Stop opening Adobe Reader after plotting to .pdf
    By LG24 in forum AutoCAD Drawing Management & Output
    Last Post: 7th Apr 2010, 10:10 am
Tags for this Thread
