Results 1 to 6 of 6
    Forum Newbie
    Electrical
    AutoCAD 2015
    Jul 2017
    5
    Question Viewports and Layer State Relation
    I have a drawing with multiple Viewports using different Layer States. How do I know which Layer State is being used in each Viewport.
    Full Member isutheparambil's Avatar
    Electrical
    isutheparambil's Discipline Details
    Designer/Draftsman-Electrical / CAD Coordinator
    Electrical
    A qualified Electrical CAD Designer Draughtsman with a solid experience in Electrical CAD designing and drafting of Multi-storied building, Shopping complex, Palace, Mosque, Luxury Villas etc. with the design department of multinational companies for the various types of electrical design.
    AutoCAD 2014
    Jul 2013
    United Arab Emirates
    76
    One layer can be used for all the viewports.
    Each viewports can the option to on off or freez the same layer from the viewport itself.
    Clarify your actual requirement.
    Forum Newbie
    Electrical
    AutoCAD 2015
    Jul 2017
    5
    I realize each viewport has the option to on off or freeze the same layer from viewport to itself, but if you have viewport A with Layer State 1 applied and & viewport B with Layers States 2 applied. How can i check that viewport A is actually using Layer State 1 and not Layer State 2? (other than manually applying each Later State and visually checking each to look if it correctly matches) is there some sort of property in the viewports that tells you which layer state is applied.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,216
    As far as I know, there is no connection between layer states and viewport settings for layers. It could be a handy thing to have, but it's complicated to implement. You may be able to store a VIEW with a layer state, but I haven't worked with those.
    breaking AutoCAD on a regular basis since 1991
  5. #5
    Electrical
    Electrical
    AutoCAD 2014
    Jul 2013
    76
    Quote Originally Posted by Tudors View Post
    There is a way that you can edit the description on the LAYERSTATE manager that as like "LAYERSTATE-1 for Layout-1"
    See the attached image.
    Hope this will helpful for you.
    https://www.dropbox.com/s/mm81m0jqbzg1cab/test.jpg?dl=0
  6. #6
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by CyberAngel View Post
    CyberAngel is correct, additionally, you could use named Views, each of which can include what is called a layer SNAPSHOT.
    When you select one of your named views, the layer snapshot will be activated, defining visibility of layers within the viewport.
    In that way when you click into a viewport to activate it, you can easily see the name of the saved view it is displaying, and you can select from any saved views in the .dwg, should you need to use a different one. Each saved VIEW will be predefined, including any current Layer settings (Snapshot), when created, if you choose the SAVE LAYER SNAPSHOT WITH VIEW option.
  1. Layer color changes with Layer State
    By Crazy J in forum AutoCAD Drawing Management & Output
    Last Post: 15th Feb 2010, 11:18 pm
  2. layer state combo box
    By MR MAN in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Jan 2010, 02:48 am
  3. layer state
    By bstegemann7788 in forum Tutorials & Tips'n'Tricks
    Last Post: 18th Jul 2008, 01:41 am
  4. ssm and layer state
    By VJMP in forum AutoCAD Drawing Management & Output
    Last Post: 19th Sep 2007, 11:26 pm
  5. No option to save layer state in layer manager - Help!
    By cameronsf in forum AutoCAD Drawing Management & Output
    Last Post: 9th Feb 2005, 11:50 am
Tags for this Thread
