Results 1 to 7 of 7
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Default LISP to make text middle justified
    Hello, Is there a LISP to make text middle justified?
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    And, preferably begin the move command grabbing the center basepoint, since that's usually what happens next in order to move it to the middle of an object.
    Senior Member
    StevJ's Computer Details
    Xp Pro
    AutoCAD 2014
    Sep 2008
    Bremerton, Wa
    140
    Take a look at this as maybe a place to start.
    Steve
    Senior Member
    iconeo's Computer Details
    Windows
    Multi-disciplinary
    iconeo's Discipline Details
    CAD Manager/Draftsman
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    306
    I use the following as a macro.
    Code:
    ^C^C(COMMAND "LAYER" "M" "S-ANNO-TEXT" "C" "7" "" "") 'textstyle standard 'textsize $M=$(if,$(=,$(getvar,cvport),1),0.0703125,$(*,0.0703125,$(getvar,dimscale))) mtext \j bc w 0;
  5. #5
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    bump bump bump bump
  6. #6
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,454
    One of the first associations I did was from this code from Tharwat,
    pointing out this fragment from his code:
    Code:
      (vla-put-attachmentpoint mt acmiddlecenter)
      (vla-move mt (vla-get-insertionpoint mt) p)
    Later I was doing such stuff in my codes aswell, but I'll always remember that thread he helped me.
  7. #7
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Quote Originally Posted by Grrr View Post
    Code:
    Code:
    (DEFUN C:mJ ()
    Thank you for trying but it doesn't look like that one worked.
  1. Make it stop! autosaving in the middle of a command
    By MikeP in forum AutoCAD General
    Last Post: 2nd Nov 2017, 05:45 pm
  2. Dynamic Block - Rotating Attribute from Left Justified to Center Justified
    By dyanner in forum AutoCAD Drawing Management & Output
    Last Post: 18th Nov 2013, 09:09 pm
  3. Looking for a lisp to make the text in block unmirror
    By ichlove in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Nov 2009, 11:35 am
  4. Need lisp to Align text to middle center of a box/rectangle?
    By Ste1978 in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Nov 2007, 03:56 pm
  5. Right justified quick leader text
    By Siberian in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jul 2006, 05:11 pm
Tags for this Thread
