Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    65
    Default Numbering equipment with text LSP
    Hello,
    Does anyone know of a LSP out there that will number the selection below properly without editing each piece of text?
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    65
    Also, anyone know if a way where you could rotate the entire selection by 90 degrees and the text rotates with it? Would want that as a totally separate LSP if possible. thanks!
    Full Member
    AutoCAD 2010
    Oct 2015
    92
    To create an array and increment each number then look at Lee Macs INCARRAY lisp and INCARRAYD
    Full Member
    AutoCAD 2010
    Oct 2015
    92
    as for your second question, I depends how many times you need to do this, I would just rotate it and use the properties menu to set the text rotation.. but there might be a smart way to do all that in one go
  5. #5
    Super Member asos2000's Avatar
    asos2000's Computer Details
    WinXP
    AutoCAD 2007
    Sep 2007
    Cairo Egypt
    672
    Sorry for my English.
  6. #6
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    65
    Not what I was looking for but thanks for the response.
    I am looking for a LISP where I select all the text objects and it can order them from the first number to the last text object in increments of one. I do not like arrays.
  7. #7
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    65
    tcount works great. thanks!
  8. #8
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    681
    Here's another:
    Code:
    (defun c:number	(/ i s)
      (setq i 0)
      (if (and (setq s (ssget ":L" '((0 . "text")))))
        (foreach e
    	     (vl-sort (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
    		      '(lambda (a b) (> (caddr (assoc 10 (entget a))) (caddr (assoc 10 (entget b)))))
          (entmod (append (entget e) (list (cons 1 (itoa (setq i (1+ i)))))))
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,460
    There's also this.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  10. #10
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,171
    If you use annotative text an option is set angle to view so if you rotate what you have the text will rotate back to horizontal.
  1. Multi Text Numbering
    By WERDNA in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th Dec 2012, 01:46 pm
  2. can I sort the text by numbering
    By e.mounir in forum AutoCAD Beginners' Area
    Last Post: 26th Mar 2010, 02:19 am
  3. Automatic Text Numbering
    By Vikes_Fl in forum AutoCAD General
    Last Post: 23rd Jun 2009, 05:28 pm
  4. Text numbering
    By wannabe in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Jan 2009, 02:57 pm
  5. Text Formating Numbering
    By venuj99 in forum AutoCAD General
    Last Post: 6th Jan 2009, 02:44 pm
Tags for this Thread
