+ Reply to Thread
Results 1 to 1 of 1
  1. #1
    Forum Newbie
    Rhino not applicable
    Join Date
    Aug 2017
    Default Extrusion surfaces broken up
    I am having trouble with rhino mac creating horrible surfaces. I have extruded a curve and it has resulted in messed up surfaces even though it is a simple straight extrusion. I first thought that rhino was just displaying them strangely but i have taken the object into keyshot and the textures are all over the place. I have tried redoing the extrusion, redoing the curve and extruding that and duplicating the edge needed and extruding that to no avail. I have even started a completely new model/file and the same thing is happening here.
    It also seems to be preventing me from doing things to the object. I cannot use the boolean functions on it. When I try and fillet the edges I cannot select some and others all select at the same time.
    I have attached images of the original file and a simple example of what is happening. Any help would be appreciated.
Similar Threads
  1. Broken OLE link
    By lkenshalo in forum AutoCAD Drawing Management & Output
    Last Post: 31st Jul 2014, 05:57 pm
  2. Broken-out section help
    By brow_tines in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Nov 2013, 04:39 pm
  3. MEP broken?
    By dumfatnhappy in forum MEP
    Last Post: 26th Apr 2012, 05:10 pm
  4. Is UCS broken in Acad 2010, or just broken in general?
    By MatthewDS in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Mar 2010, 11:23 pm
  5. Broken Line
    By Hoover in forum AutoCAD Beginners' Area
    Last Post: 17th May 2007, 05:10 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
