Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Junior Member
    Manufacture
    AutoCAD 2017
    Aug 2017
    10
    Default select 1 segment of a polyline?
    Hello. Im trying to ween myself off of bobcad, and teach myself autocad 2017. Its difficult, as nothing is even similar. I have drawn a rectangle as a polyline, and I need to select only 1 line segment, the top line, and make a parallel line 5 units down. When I try to do this, it selects the entire rectangle and offsets it. I dont want that. I just want to make a simple single parallel line. Surely im just missing a step here. it cant be a difficult thing to do. Must I somehow explode the polyline into segments? If so, how? I tried pedit, but nothing seemed to work. Is there a way to manually select a single segment of a polyline?
    Thanks for your time!
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,201
    Use the OFFSET command and offset the rectangle 5 units. Then EXPLODE the offset rectangle and delete the segments you don't want.
    Or you could try this lisp routine created by Lee Mac: http://www.lee-mac.com/offsetpolysection.html
    Here's another lisp routine: https://autocadtips1.com/2011/07/04/...line-segments/
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Junior Member
    Manufacture
    AutoCAD 2017
    Aug 2017
    10
    I was thinking to explode the original rectangle so I could select a single line, but cannot figure out how to make the explode function work. In bobcad, every line segment is picked as a single, or as a polyline by using the shift key. So, its easy to just pick a line, and do what ever with it. Shouldnt there be a way to select just 1 line segment without jumping through hoops?
    Junior Member
    Manufacture
    AutoCAD 2017
    Aug 2017
    10
    Ok, there must have been a glitch? I just got the explode function to work. On a side note, the drawing recovery manager would not work. It froze up and would give a preview of the desired drawing, but when double clicked, it would freeze up and then render the old un saved version. I think may be thats why i couldnt get explode to work. So, I closed down, did not try to recover, and just proceeded to try the explode function. Thanks very much for the help!
  5. #5
    AutoCAD 2013
    Nov 2011
    5,986
    Welcome to CADTutor bmz.
    Do yourself a huge favor and follow this link, you will save yourself a lot of time and frustration.
    https://www.mycadsite.com/
  6. #6
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    Southern California
    10,201
    Quote Originally Posted by bmz View Post
    If you want to delete a line segment from a Polyline, you can initiate the ERASE command, then hold down the Ctrl key and click on the line segment you want to remove, but this functionality doesn't work if you want to Copy, Move, Offest etc. That's where you need a custom lisp routine like the ones I linked in my previous post.
    Facebook:
  7. #7
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,029
    If the pline is drawn square then a simple way to do 1 side is draw a line picking the 2 pline points, then use move pick line or L for last make sure ortho is on F8 pick a point then drag in direction required with mouse, then type offset distance, all done. If its on angle again same method but using a UCS OB to set ortho angle. Do same again then UCS W
  8. #8
    Junior Member
    Manufacture
    AutoCAD 2017
    Aug 2017
    10
    I def appreciate all your guys help! In the future, I may have to plan my drawings more carefully to try and avoid redundant key strokes. For example,, having to hit enter to repeat a function, then having to reenter the numerical value for that function every time. What if I need fifty holes in a panel? Do I need to hit return a total of 150 times, and reenter the numerical value 50 times?!
  9. #9
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,643
    Are all fifty holes the same size?
    Are all fifty holes spaced the same distance apart?
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,643
    If you wanted every single line to be a separate entity then you should have used the Line command not the Polyline command.
  1. How to offset multiple polyline from one segment
    By handasa in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st May 2017, 01:14 am
  2. Find the length of an AutoCAD polyline segment
    By nopasaran in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th May 2010, 03:40 pm
  3. Replies: 15
    Last Post: 5th May 2010, 06:16 am
  4. Perpendicular on Given Polyline with given segment
    By samcoozy in forum AutoCAD Beginners' Area
    Last Post: 11th Apr 2010, 02:52 pm
  5. Segment Arc Polyline?
    By JaketheMan in forum AutoCAD General
    Last Post: 27th Aug 2007, 03:46 pm
