Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    Junior Member
    Manufacture
    AutoCAD 2017
    Aug 2017
    10
    In reference to the holes question, yes all holes the same size. Location would normally be snap to an intersection, or to the center of another radius.
    Also, yes I figured that using the line function would have been better to start with then join them.
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Well if the holes were in some sort of fixed pattern you could use the ARRAY command.
  3. #13
    Junior Member
    Manufacture
    AutoCAD 2017
    Aug 2017
    10
    Hmm. Perhaps I will investigate placing points instead of holes. The points represent drill points in the final g code output, and so they dont actually need to be a curved drawn hole. It is nice to see the holes though so spacial relationships can be seen and not imagined.
  4. #14
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    using Object Snap Tracking would be an another way to do what you want.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  5. #15
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,169
    If the "Circles" are in a line etc and some form of repeated distances required you could make some shortcuts that ask for spacing and copy an object multiple times you could do something like 3x40L followed by 5x20U.
    ie copy 3 times at spacing of 40mm the u d r l up down right left
    Sorry just an idea no code. It may be out there already.
  6. #16
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,118
    Back tracking to the original question, holding down the Ctrl key and selecting a polyline will allow you to select individual segment(s), you can delete the selected segments even non continuous parts, unfortunately offset only still works on the whole polyline but after selecting and then using the shift key you can get some nice transformations.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  7. #17
    Junior Member
    Manufacture
    AutoCAD 2017
    Aug 2017
    10
    Thats fantastic! At least its another option when an entire polyline is offset. Its still too bad though that instead of being able to pick 1 segment of a polyline for offset, one must jump around the issue either with better planning, or by work around procedures. All these tips presented are excellent fixes for when there is needed a work around. I guess next drawing will be done without the polyline command as much as possible then it shouldnt be a problem. Hoping that will not present any problems!
  1. How to offset multiple polyline from one segment
    By handasa in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st May 2017, 01:14 am
  2. Find the length of an AutoCAD polyline segment
    By nopasaran in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th May 2010, 03:40 pm
  3. Replies: 15
    Last Post: 5th May 2010, 06:16 am
  4. Perpendicular on Given Polyline with given segment
    By samcoozy in forum AutoCAD Beginners' Area
    Last Post: 11th Apr 2010, 02:52 pm
  5. Segment Arc Polyline?
    By JaketheMan in forum AutoCAD General
    Last Post: 27th Aug 2007, 03:46 pm
