Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 35
    Junior Member
    JGupte's Computer Details
    Windows 7
    Construction
    JGupte's Discipline Details
    Document Controller/Report Writer
    Construction
    AutoCAD 2016
    Aug 2017
    Sydney, Australia
    15
    Default AutoCAD Title Block from EXCEL VBA
    Hi All,
    I am trying to write a VBA script that will run from inside an Excel spread sheet to update the title block fields from values in the spreadsheet.
    I have been able to use ATTOUT to export the existing values to a TXT file and ATTIN to import the changed values. But I need to drive this from Excel VBA.
    In plain English, what I need to do is:
    Loop through all dwg files in a list
    for each dwg file,
    find the Title block values in my spread sheet and export them to a txt file (in the correct format)
    open the dwg file
    import the txt file (ATTIN)
    save and close the dwg file
    Delete the txt file
    Loop
    I am fairly proficient in Excel VBA, but not in AutoCAD.
    So far, I can create a link to AutoCAD and open the dwg file, then save and close it.
    But I can't figure out how to automate the ATTIN function.
    As I am not a Administrator on my PC (company policy) I can not install any programs of tools.
    Any help would be appreciated.
    JG
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,511
    1st up search here lots of examples that do title block update. You may be better going the other way and drive excel from Autocad this can be a simple get cell and put atribute. Likewise I am sure you can drive Autocad from excel. I have posted a vba block attribute updating code that may be usefull as I am not sure about driving from excel. There is basicly two ways to find the correct attribute to change either use its tag name or use its position order, the second method is the example here with the 1st attribute starting at 0 see attrib(0)
    Most of the excel/Autocad examples use lisp in particular code written in Vlisp is very similar method.
    getexcel.lsp is what I use there are others, it does have methods that may enable excel to control I have never had to do it that way.
    Code:
    Public Sub ModifyPitSchedule1()
    ' adds single pt
    Dim SS As AcadSelectionSet
    Dim objENT As AcadEntity
    Dim Count, Cntr As Integer
    Dim Newpitname As String
    Dim pitname As String
    Dim FilterDXFCode(0) As Integer
    Dim FilterDXFVal(0) As Variant
    Dim PitNameSelect As AcadObject
    Dim basepnt, pt1, pt2, pt3 As Variant
    Dim attribs As Variant
    'On Error Resume Next
    Newpitname = "1"   'dummy to pass then return changed
    BLOCK_NAME = "SCHEDTEXT"
    pitname = Getpitname(Newpitname)
    MsgBox "pitname selected is " & pitname
    FilterDXFCode(0) = 0
    FilterDXFVal(0) = "INSERT"
    'FilterDXFCode(1) = 2
    'FilterDXFVal(1) = "SCHEDTEXT"
    Set SS = ThisDrawing.SelectionSets.Add("pit1sel")
    SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal
    For Cntr = 0 To SS.Count - 1
    If SS.Item(Cntr).Name = BLOCK_NAME Then
       attribs = SS.Item(Cntr).GetAttributes
         If attribs(0).TextString = pitname Then
           pt1 = ThisDrawing.Utility.GetPoint(, " pick first point")
           txtx1 = CStr(FormatNumber(pt1(0), 3))
           TXTY1 = CStr(FormatNumber(pt1(1), 3))
            attribs(1).TextString = txtx1
            attribs(2).TextString = TXTY1
            attribs(1).Update
            attribs(2).Update
    '        ThisDrawing.Application.Update
    ' try this
            Cntr = SS.Count
         Else: End If
     Else: End If
    Next Cntr
    ThisDrawing.SelectionSets.Item("pit1sel").Delete
    End Sub
    Junior Member
    Windows 7
    Construction
    Construction
    AutoCAD 2016
    Aug 2017
    Sydney, Australia
    15
    Hi BIGAL,
    Thanks for the reply.
    The reason for driving this from Excel instead of AutoCAD is that we need to update several thousand drawings with data in one Excel spread sheet.
    I would like to use the tag name method, and update an existing tag with a value from the spread sheet.
    E.G.
    Tag Name = "TPDDRAWINGNO"
    Current value = "TPDDRAWINGNO" (from template"
    Desired value = "SLR-ALS-D50-CSR-DWG-063201"
    These will all be in the title block.
    The procedure will loop through the spread sheet and update each drawing appropriately.
    I have my data in one line per drawing with the tags as the column headings.
    JG
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,149
    Can you post the code that you have up to now. It would be easier for someone to help if they have a starting point to work from.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  5. #5
    Junior Member
    Windows 7
    Construction
    Construction
    AutoCAD 2016
    Aug 2017
    Sydney, Australia
    15
    I don't really have much code yet. Just the basic to start AutoCAD and open the drawing.
    Code:
    Sub Open_DWG()
        Dim strDrawing As String
        Set ACAD = GetObject(, "AutoCAD.Application")
        If Err.Description > vbNullString Then
            Err.Clear
            Set ACAD = CreateObject("AutoCAD.Application")
        End If
        ACAD.Visible = True
        xDWGPath = "C:\Users\297560\Documents\Development\AutoCAD Update\"
        Range("A2").Select
        xDWGFile = ActiveCell & ".dwg"
        xDWGFull = xDWGPath & xDWGFile
        ACAD.Documents.Open (xDWGPath & xDWGFile)
    End Sub
    I am trying to create the project from scratch, and trying various bits of code I am finding on the web.
    When creating Excel macros, I usually start by recording a macro to do the basic stuff I want, then modifying the code to add loops, error checking, etc.
    But in AutoCAD I can't figure out how to record the macro (I tried Action Recorder, but could not find how to edit the code generated).
    JG
  6. #6
    Forum Newbie
    AutoCAD 2014
    Feb 2016
    2
    I want to autocad text command apply from excel cell- like "-text "&Crossing!B3&",-4.5 0 Distance"
    but i can only one text write from one cell, how can i do multi text write from one excell text to autocad from different position
  7. #7
    Forum Newbie
    AutoCAD 2014
    Feb 2016
    2
    but i can only one text write from one cell, how can i do multi text write from one excell text to autocad from different position..
    Like:
    Distance (Position 4,5)
    Elevation (Position 4,7)
    Please help any body
  8. #8
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,149
    I can't comment on the merits of working this way, I'm new to full Autocad but was interested to find out how to issue commands from Excel, so building on what you posted, this code will update the attributes in all the drawings in a list.
    I used the -attedit command as this doesn't require you to write multiple txt files and so just a simple loop will suffice, I had drawing names in column A (starting at A2) then old attribute values in column B and new values in column C, I only ran this on 3 simple drawings and each one only had a single layout and attributed block, so there is no error checking or changing to the correct layout, but it worked. I would advise making a complete backup of any folders you use before running any Code, and take a look in the help files about the -attedit command for possible changes in the layout of how you can use it.
    Code:
    Sub Open_DWG()
     Dim acadCmd As String
     Err.Clear
     End If
     ACAD.Visible = True
     xDWGPath = "D:\Autodesk support\Drawings\"
    'xDWGPath = "C:\Users\297560\Documents\Development\AutoCAD Update\"
     For x = 2 To 4
     Cells(x, 1).Select
     acadCmd = "-attedit n n " & vbCr & "TPDRAWINGNO" & vbCr & Cells(x, 2).Value & vbCr & Cells(x, 2).Value & vbCr & Cells(x, 3).Value
     ACAD.ActiveDocument.SendCommand acadCmd & vbCr
     ACAD.ActiveDocument.SendCommand "qsave close" & vbCr
     Next
    End Sub
  9. #9
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
  10. #10
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,149
    I have to add here the code posting tags icon doesn't do anything for me, not sure if it's a browser problem (IE) or just broken on the site, but I have to manually type in the CODE tags
  1. Insert a title Block from excel into a opened dwt with excel vba
    By alex140590 in forum .NET, ObjectARX & VBA
    Last Post: 15th Jul 2016, 11:43 am
  2. Replies: 9
    Last Post: 19th Apr 2016, 03:43 pm
  3. Title block to excel spreadsheet
    By keiths in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Dec 2013, 07:26 am
  4. Excel spreadsheet to update autocad drawing title block
    By Jasenc in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Feb 2013, 12:47 pm
  5. EXCEL Drawing register using Autocad Title Block Attributes
    By SimonC in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2010, 03:40 am
