Results 1 to 8 of 8
    Junior Member
    Electrical
    AutoCAD 2013
    May 2017
    17
    Default Can't explode a block
    Please could someone assist me in helping me explode a block? tried standard way and also going in via block editor, properties etc. to no avail. Please see attachment for drawing. Thanks for any input.
    Westfield1.dwg
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    Works for me. I went into the block editor, Properties and set the property to "Allow Exploding".
    The block is a Dynamic Block though, so once you explode it you will lose all the dynamic functionality.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Junior Member
    Electrical
    AutoCAD 2013
    May 2017
    17
    Hi CAD64, thanks for replying. Please can you tell me where the 'Allow exploding' option is? I can't see it when I'm properties and I am using autocad 2013.also do you need to highlight part of the block first then right click properties? Thanks
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    Click on the block to select it, then right click and choose "Block Editor" from the pop up menu. Once you are in the block editor, there is an option in the Properties to "Allow Exploding". Set that to "Yes" and then save and close the block editor. Now you will be able to explode the block.
    Facebook:
  5. #5
    Junior Member
    Electrical
    AutoCAD 2013
    May 2017
    17
    Thank you very much.
  6. #6
    Junior Member
    Electrical
    AutoCAD 2013
    May 2017
    17
    Also is there a way to explode the block without the text within it altering? Or is this what you meant with the dyno?
    Basically i need to make certain objects within the block one colour and others another colour. If this can't be achieved without messing up the text is there a function where I can highlight over certain objects without the need to explode and change their colour? Thanks
  7. #7
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    The text is altering when you explode the block because the text is an attribute. If you want it to stay the same, use the BURST command instead of EXPLODE. But, since this is a dynamic block, when you run the BURST command, it's going to make a mess of things and throw a lot of extra text objects around which you will have to clean up.
    Facebook:
  8. #8
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    Why can the colors not be changed within the block editor, rather than explode the block? Is it that you need only one or two instances of the same block with different colors? If so, a block can be Saved As another block name after edits. Just changing colors will not affect the dynamic parameters, nor the attributes of the block. The original block will still be there under the original name.
    Once you have made edits to the block, you can either type the command BSAVEAS, or click the Open/Save drop down button, under the Edit Block & Save Block tiles at the far left of the block editor ribbon. See image.
    Give the new one a unique name, like original name-red and green, or whatever fits your fancy.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  1. Block explode
    By thbaiju in forum AutoCAD General
    Last Post: 3rd Jul 2014, 08:24 am
  2. Please can you explode this block
    By wimal in forum AutoCAD General
    Last Post: 20th Mar 2013, 07:29 am
  3. Explode block placed with VBA
    By wbluem88 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Feb 2010, 11:30 pm
  4. Explode block / explode text command
    By repelectric in forum AutoCAD General
    Last Post: 3rd Aug 2009, 09:52 pm
  5. Explode Block
    By vinod in forum AutoCAD General
    Last Post: 23rd Sep 2008, 08:40 am
