Results 1 to 5 of 5
    Forum Newbie
    Mechanical
    AutoCAD 2017
    Aug 2017
    1
    Default Need LISP Function to read text contents and convert ratio to number.
    I have a vector map of a floor and all i am given are vectors and grade ratios (i.e. 1:155.095, 1:97.561) of the floor. The problem is that I only want to look at the areas of the floor that are below a certain grade ratio (1:69), but they are ratios set as Text Contents so AutoCAD doesnt understand that these ratios are numbers.
    I am looking for a Lisp function that, for each text if a ratio across an entire floor (or the layout), copy the text (which is a ratio), find out the number that the ratio is (i.e. take the 1 and divide by 69), then replace the text with just the number (0.0145). I want this to do this for every instance, and there are over 37,000 of these texts on the floor in question.
    I have attached an image that depicts what I have in the layout.
    Does anyone know of a lisp function that can do this?
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,595
    Quickly written:
    Code:
    (defun c:fixratios ( / a b e i p s x )
        (if (setq s (ssget "_:L" '((0 . "TEXT")(1 . "#*:#*")(1 . "~*[~.:0-9]*")(1 . "~*:*:*"))))
            (repeat (setq i (sslength s))
                (setq e (entget (ssname s (setq i (1- i))))
                      x (cdr (assoc 1 e))
                      p (vl-string-position 58 x)
                (if (and (setq a (distof (substr x 1 p) 2))
                         (setq b (distof (substr x (+ 2 p)) 2))
                         (not (equal 0.0 b 1e-8))
                    (entmod (subst (cons 1 (rtos (/ a b))) (assoc 1 e) e))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,711
    Hi Lee needs a second part say a copy of the text onto a different layer where the result is < 1/69 0.0144927536 this is part of the request, maybe a seperate defun this way the code re grade remains intact.
    had a little bit of time.
    Code:
    ; original code by Lee-mac Aug 2017
    ; changed to only modify 1:x below 1:69
    ; by Alan H Aug 2017
    (defun c:fixratios ( / a b e i p s x ab)
    ; new layer added
    (if (/= (tblsearch "Layer" "Xgrade") nil)
          (setvar 'clayer "Grade2")
          (command "-layer" "m" "Xgrade" "c" 10 "Xgrade" "")
        (setq e (vlax-ename->vla-object (ssname s (setq i (1- i)))))
        (setq x (vla-get-textstring e))
        (setq p (vl-string-position 58 x))
        (if (and
              (< (setq ab (/ a b)) (/ 1.0 69.0))
                (vla-put-textstring  e (rtos ab 2 3))
                (vla-put-layer e "Xgrade")
    Senior Member devitg's Avatar
    devitg's Computer Details
    XP
    VG2021WM VIEW SONIC
    AutoCAD 2008
    Apr 2005
    CORDOBA ARGENTINA
    170
    Hi lee , nice lisp.
    Could you explain
    Code:
    About the 1 filter
    Also it can be add the 8 dxf code to TABLE , as it is the text's layer.
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,595
    Quote Originally Posted by devitg View Post
    Could you explain
    Code:
    About the 1 filter
    (1 . "#*:#*")
    Matches text starting with a number and containing a colon followed by a number, e.g. "1abc:2def"
    (1 . "~*[~.:0-9]*")
    Matches text which only contains the characters ".:0123456789", e.g. "1.23:4.56:7.89"
    (1 . "~*:*:*")
    Ensures that the string only contains one colon.
    This doesn't account for all cases, as you could perform additional validation on the decimal point (ensuring it appears at most once on either side of the colon).
    The layer filter could also be included, but it would reduce the ability for other members to easily use the code.
  1. LISP to read text label as attribute in properties
    By Jakub in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Apr 2016, 09:51 am
  2. convert the number to text number in Arabic language
    By mahmoudqaswal in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Apr 2016, 11:00 am
  3. A non lisp way to populate a table with contents of text objects?
    By YZ in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 26th Nov 2015, 09:30 am
  4. Record a Macro and Then Read the Action File Contents
    By Brenda Tanner in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 10th Jul 2012, 08:38 pm
  5. Convert .dwg to PDF and retain scale ratio
    By Bill.3 in forum AutoCAD Beginners' Area
    Last Post: 15th Mar 2009, 09:51 pm
Tags for this Thread
