Results 1 to 5 of 5
    Full Member
    deano33's Computer Details
    XP/7/Ubuntu
    P3/P4/I7
    PEN(DUAL CORE)-P4 2GHZ-PIII 850
    8GB
    HVAC
    deano33's Discipline Details
    Projects Manager & Engineer
    HVAC
    AutoCAD LT 2012
    Nov 2006
    BIRMINGHAM, ENGLAND
    78
    Default Ditch the useless ribbon
    How do I get rid of the ribbon and get classic view back on autocad lt 2016. Time is money and the extra clicks required for the ribbon are to expensive lol.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,115
    You can always learn the Ribbon and set it up to be just as fast, if not faster.
    But the best way I've found is to follow this process:
    Type at the command line -TOOLBAR and type a known Toolbar such as Standard and hit Enter. Then type RIBBONCLOSE and set MENUBAR to 1. Now with the one toolbar open you can right click and open all the Toolbars your heart desires.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    813
    I struggled 12 years ago when the CUI was introduced, I'd been using AutoCAD for 13 years already and even taught a course on customizing it in 2003. It wasn't easy, but I since found that organizing everything into tabs and panels that often switch automatically switch for modifying many objects as well as for many commands. The Ribbon format started with Windows Office software, but AutoCAD has taken it further than Office. The Ribbon allows organizing hundreds of commands and features not possible before. The only toolbar I use now is the Quick Action Toolbar where I can undo the last 28 commands by selection or thaw a layer and change it's color.
    I encourage you to give it an honest try, remember what happens to those who can't keep up.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    291
    Use hotkeys. :-)
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,096
    Keyboard and custom shortcuts, hotkeys are the fastest. Learn them, doesn't matter if the ribbon is there or not, I have the Ribbon reduced to tabs at the top.
  1. how to delete useless .dwg file when using .dwt
    By dunno790 in forum AutoCAD Beginners' Area
    Last Post: 11th Nov 2015, 08:56 pm
  2. Omitting Tons of Useless Text From my console window.
    By kapat in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Nov 2012, 06:24 am
  3. Ditch dialog boxes with the command-line form of commands
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 23rd Feb 2012, 09:20 am
  4. Comand to eliminate useless lines
    By hydro in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Mar 2008, 02:46 am
  5. Civil Design Ditch Alignment Questions
    By UTCiv in forum AutoCAD Drawing Management & Output
    Last Post: 13th Feb 2007, 06:42 pm
