Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 24
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    So, in other words, you are going to what? A full reinstall on the same computer OR a new installation on a different computer?
  2. #12
    Full Member
    AutoCAD LT 2014
    Nov 2015
    35
    I have an older computer running Windows XP so I shall put it on there, I hope. It is not connected to the internet so it should be OK. It has been connected to the plotter before so it should be OK. As I said before, I just need to carry out amendments on existing drawings and print them off.
  3. #13
    Super Member nukecad's Avatar
    nukecad's Computer Details
    Win 10 home.
    Various machines.
    AutoCAD 2000i
    Apr 2009
    NW Cumbria (English Lake District)
    712
    Just to jump in with a suggestion here.
    Have you tried "Compatibility Mode"?
    This will often let software that was meant for older Windows versions run properly on Windows 10.
    The quickest way to get to it is to open the Start Menu and just type the word compatibility.
    That will then show you a shortcut to the compatibility troubleshooter.
    Running this will search your computer for installed programmes and ask you to select the one you are having problems with.
    It will then try to work out the best way to fix the particular problem.
    More about the troubleshooter and Compatibility Mode:
    https://support.microsoft.com/en-gb/...ams-compatible
    This article also shows how to manually set a programme to run in Compatibility Mode.
    https://www.laptopmag.com/articles/s...ode-windows-10
    *** Out of Beer Error ->-> Recovering Memory***
  4. #14
    Full Member
    AutoCAD LT 2014
    Nov 2015
    35
    Hi Nukecad. Thanks I tried that using windows 8 settings but autocad is still crashing. I assume that the programme has become corrupted? I was thinking of taking bigal's advice and repairing from the DVD, but there appears to be no repair tool. I assume if I do a reinstall I will need to contact autodesk to activate. Thus far they have not been helpful, and have not responded to my request to load the software onto another PC under the same licence. I assume their solution is to buy the latest copy of their software, which I am unable to do.
  5. #15
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    The program may not be corrupted however a Windows 10 setting or settings may have changed thus causing the problem.
    You do not need the DVD to do a repair however you would need it if you were to do a complete uninstall/reinstall.
    Activation codes are normally obtained via an Internet connection. You do not call or email AutoDesk to obtain one.
    I think you have two options.
    1) You do a complete and thorough uninstall / reinstall of AutoCAD 2014 on your Win10 system.
    2) You install AutoCAD 2014 on the other computer you mentioned that is running WinXP.
    If both methods fail then I'd suggest looking at purchasing an AutoCAD clone like BricsCAD which by comparison is relatively cheap or you download the FREE 2D CAD program Draftsight (another AutoCAD clone) from the Dassault Systemes website.
    As I said before, do NOT expect any assistance from AutoDesk since your version of AutoCAD is not supported under Windows 10.
  6. #16
    Full Member
    AutoCAD LT 2014
    Nov 2015
    35
    Hi, I made some progress! I have managed to decipher some of the instructions given out be Autodesk and have exported the license from the original PC to their server. I have loaded the software onto another PC, successfully. The instructions then tell me to locate the License Transfer Utility File(LTU) in the AutoCAD directory click on it, enter my details etc and import the license. The problem now is, there is no LTU file to be found?
    That said, the programme is working OK. I have opened it a couple of times now and expected to see a "30 day trial" or "activate" button, but none appear? I have sent an email off to Autodesk for clarification.
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    From the AutoDesk website....
    "If you can't find the LTU, your product may not support license transfers or the LTU hasn't yet been installed with your product. The LTU is installed by default, but it is an optional component that can be de-selected in the product installer. You may need to install the LTU from your original installation media."
  8. #18
    Full Member
    AutoCAD LT 2014
    Nov 2015
    35
    Hi ReMark, I followed the following process advised by autodesk:
    https://knowledge.autodesk.com/custo...sfer-using-ltu
    I found the LTU File and exported the license from the old PC no problem. This worked because I was not able to activate the software any longer.
    I loaded the software onto another PC running Windows 7, from the original DVD entering the serial number and product key. Once loaded, I searched, high and low, for the LTU file as indicated in the directions given above, but it is not there?
    I have been onto autodesk via their chat line and they are asking me for a "Request Code". This I understand is obtained by clicking on an activate button that should appear on my screen. This is not there either.
    In fact the software is up and running as normal. So perhaps I should leave it at that? My worry is that if the license has not been activated will I lose it after 30 days?
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    So when you boot up you do NOT see a screen that looks like this?
  10. #20
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Another option for product license activation is to manually request an activation code. If your software is legitimate (i.e. - not pirated) AutoDesk will send you the 32 character activation code via email which you would then have to manually enter. But to do so you would have to access the above screen where you would click on the "Activate" button in the lower right hand corner to start the process. If you are not seeing the screen then you must have activated AutoCAD without knowing it or the license transfer utility somehow worked its magic without you knowing it.
    You can check for the presence of an activation code.
    When you install your Autodesk product using a valid serial number and product key, an HTML file containing your request code and registration information will be saved on your computer, typically in the following location:
    For Windows Systems: C:\ProgramData\Autodesk\Adlm\ProductNameVersion_USRegInfo.html
    I think your product name version would be ACDLT2014en.
  1. Crashing
    By finn379 in forum AutoCAD General
    Last Post: 13th Jan 2012, 04:43 pm
  2. C3D crashing
    By Openantics in forum Civil 3D & LDD
    Last Post: 26th Apr 2011, 02:05 am
  3. MEP is crashing!!!!
    By Interspace 2003 in forum MEP
    Last Post: 20th May 2010, 10:05 pm
  4. My CAD keeps crashing!
    By MRAKA in forum AutoCAD Drawing Management & Output
    Last Post: 28th May 2009, 04:29 pm
  5. Cad crashing
    By donahd in forum AutoCAD Drawing Management & Output
    Last Post: 16th Feb 2005, 05:03 pm
