Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member
    AutoCAD 2013
    Oct 2009
    40
    Default Intersection Problem
    Good afternoon,
    I am having a problem lately where every now and then i cannot pick up an intersection snap point. I thought the Z values might be different, but they are all at zero. To further complicate things, i can use one of the lines to trim the other, but still no intersection snap is there. I can run the FLATTEN command, and that will allow the intersection (sometimes i need to run it twice). It is confusing, as the flatten apparently fixes the problem, but according to the properties pane, there was no problem with the z value.
    I have attached a small drawing showing the problem.
    thanks
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    I tried many different variations of trimming using the five lines and they all worked without a problem.
    I also checked the Z values, did an Erase > All (just to see how many object were reported back) and even ran Overkill (no duplicate or overlapping lines). I don't think there is a problem with the drawing itself.
    Full Member
    AutoCAD 2013
    Oct 2009
    40
    thanks for the input. did osnaps show you an intersection ?
    Senior Member
    AutoCAD 2009
    Oct 2012
    320
    You use inches.
    Inches do not give an exact result.
    Run the command :
    _units
    Set the format to Decimal
    Set the accuracy to 0.00000000
  5. #5
    Full Member
    AutoCAD 2013
    Oct 2009
    40
    coolio. Thanks heaps for the help.
  6. #6
    Full Member
    AutoCAD 2013
    Oct 2009
    40
    that did not seem to work. Any other suggestions ?
  7. #7
    Senior Member
    AutoCAD 2009
    Oct 2012
    320
    What does not work ?
    Have you broken Autocad?
    You can not choose decimal?
    Maybe you can learn Help? Look for a "seeming intersection" ...
    Maybe you asked the question is not it true?
    Maybe you need to reset Z to 0 ?
  8. #8
    Senior Member dtkell's Avatar
    dtkell's Computer Details
    Win7
    Intel I5 4670
    16mb
    Civil
    dtkell's Discipline Details
    Drafter/Designer
    Civil
    AutoCAD 2014
    Dec 2006
    San Diego, CA, USA
    148
    maybe you will have better luck with "APParent intersection".
  9. #9
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,234
    Quote Originally Posted by andrew239 View Post
    As maratovich described, your lines are not all sitting at Z0. The magenta and cyan lines are at Z0, but the red lines are at Z0.00000024. That's why the intersection snap is not working.
    When I run the FLATTEN command and select the red lines, they are sent to Z0 and the intersection snap works as expected.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  10. #10
    Full Member
    AutoCAD 2013
    Oct 2009
    40
    a-ha. Thanks for the clarification. I was only getting half of maratovich's suggestion. I see it all now.
    Is there a variable that will change the sensitivity of the snap (similar to the HGAPTOL). Seems weird that they are close enough to trim with, but not get the intersection. The apparent intersection did work, but i just wanted to find out what was going on.
    Thanks again.
  1. Osnap intersection
    By Mike55 in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jan 2015, 11:51 pm
  2. Wall Intersection problem
    By qball in forum Revit General
    Last Post: 24th Mar 2014, 04:23 pm
  3. Intersection 3d
    By Lentezza in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Feb 2013, 06:43 pm
  4. dim to an intersection
    By abishop in forum AutoCAD Beginners' Area
    Last Post: 8th Sep 2010, 08:16 pm
  5. Intersection
    By smiles in forum AutoCAD Beginners' Area
    Last Post: 4th Sep 2007, 08:26 am
