+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Full Member
    Using
    AutoCAD 2007
    Join Date
    Jul 2014
    Posts
    77
    Default Invalid or incomplete DXF input
    Has anyone seen this error message, and can anything be done about it?
    Invalid or incomplete DXF input, drawing discarded.
    I received this message after converting a line drawing in the JPG format to a vector file in the DXF format, and scaling it down in size. And when the message says "discarded", that is exactly what happened, the file is gone.
    Chubarka
  2. #2
    Full Member
    Computer Details
    guigonse's Computer Details
    Operating System:
    Windows NT/7 and Linux
    Discipline
    Architectural
    guigonse's Discipline Details
    Occupation
    Architect
    Discipline
    Architectural
    Details
    Specialist in Structural Analysis
    Using
    AutoCAD 2007
    Join Date
    Sep 2017
    Location
    BARCELONA, Spain
    Posts
    29
    Default
    Well, the ERROR means what it seems: the AutoCAD's DXF parser considers the DXF file you are trying to eval as incomplete; if you can't make any more adjusts in the DXF's generator, you'll should dive the DXF (it's a plain ASCII file) searching for stranger values or incomplete sections.
    Take a look at Autodesk DXF About...
  3. #3
    Luminous Being
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    9,892
    Default
    A simple problem is a layer name can stop a dxf, you should post the dxf if thats ok.
  4. #4
    Full Member
    Using
    AutoCAD 2007
    Join Date
    Jul 2014
    Posts
    77
    Default
    guigonse, and BIGAL,
    Thank you so much for your replies. Unfortunately you are both at a much higher level of skill at AutoCAD than I, and consequently I don't have a clue as to understanding your solutions.
    I wouldn't know how to post the dxf, nor have I ever heard of adjusting a dxf Generator. If you could kindly elaborate at a lower level, I would certainly appreciate it.
    Thank you again,
    Chubarka
  5. #5
    Luminous Being
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    9,892
    Default
    Go to the "Go Advanced" option in "Reply" scroll down a bit and you will see "Manage Attachment" just pick the dxf and upload.
  6. #6
    Full Member
    Using
    AutoCAD 2007
    Join Date
    Jul 2014
    Posts
    77
    Default
    Thank you !
  7. #7
    Full Member
    Computer Details
    Operating System:
    Discipline
    Architectural
    Occupation
    Architect
    Discipline
    Architectural
    Details
    Using
    AutoCAD 2007
    Join Date
    Sep 2017
    Location
    BARCELONA, Spain
    Posts
    29
    Default
    Quote Originally Posted by chubarka View Post
    @chubaka, what I meant was that, if you can't change any parameter in the program which is generating the DXF, your only option is to edit it "by hand", which is (relatively) easy as DXF files are simple ASCII files, with a well known structure as described in Autodesk's web, at https://knowledge.autodesk.com/searc...E93CF-htm.html
    Nevertheless, it won't be an easy work, so ensure first you can't change the DXF's originator.
Similar Threads
  1. Invalid of incomplete DXF input -- drawing discarded
    By MarcS1989 in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 4th Apr 2017, 02:22 pm
  2. Errror Message :invalid input while assigning CanonicalMediaName
    By PrasadUddanti in forum .NET, ObjectARX & VBA
    Last Post: 6th Apr 2016, 04:25 pm
  3. Invalid or incomplete DXF input Error message
    By gbuckley in forum AutoCAD General
    Last Post: 11th Jun 2013, 04:02 pm
  4. Replies: 8
    Last Post: 21st Mar 2013, 02:48 pm
  5. Incomplete drawing
    By MisterJingles in forum AutoCAD Drawing Management & Output
    Last Post: 24th May 2012, 10:57 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
