Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 45
    Full Member
    AutoCAD 2007
    Nov 2006
    33
    Default command hot keys
    Is it possible to assign hot keys to all commands in a customisable way? For example if i want to draw a line, can i just hit 'L'? instead of 'L + space'
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 10
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    2TB
    Portable TB drive
    Samsung SyncMaster 226
    Mechanical
    Lazer's Discipline Details
    Design Engineering Manager
    Mechanical
    Mechanical Designer using Autocad and Inventor
    Inventor 2018
    Aug 2005
    Northants, England
    1,819
    But then you would not be able to type ltscale (linetype scale) or la (layer manager) le (quick... you get the idea. The command line is very powerfull to take away the enter(space) after a command would spoil all other commands.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,115
    Quote Originally Posted by alkorm77 View Post
    change your right-click settings in Options to where it becomes "Enter". this way you won't always have to use Spacebar.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Full Member
    AutoCAD 2007
    Nov 2006
    33
    Quote Originally Posted by deelay View Post
    I realise the command line is very powerful, and sometimes it is very useful. I'm asking if you can fully customise your keyboard for any command. So if ltscale was something you used regularly, why not make it 'alt + l' or something along those lines. What i'm suggesting can cut seconds out of each command, especially for 3D modelling. I used to use Solidworks at my previous work and along with another designer we had our Cad systems so customised for 95% of the tools we used, and was left with only one tool bar on the screen. OK, it took a couple of months to learn and there was an A3 spreadsheet stuck to my office wall with the hot keys defined for each command, but after that couple of months, in an office of 10 designers, we were modelling and producing drawings 40% faster than the other 8. Now that is productivity. So my question still stands, can you customise commands with hot keys?
  5. #5
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    Windows 7 Professional
    Dell
    Intel Xeon E5-1603@2,80GHz
    4GB
    NVIDA Quadro K600
    DELL 23" & SAMSUNG 21"
    not applicable
    Nov 2005
    Kenley, Surrey, UK
    5,644
    interesting isn't it. The 2 fastest in our office only use the keyboard with everything defined in one or two keystrokes (plus <space>). It is painful watching all the others using menus and toolbars.
    just an observation - no help to your problem.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    "Everything in drafting is logical. Except what isn’t." - Gavin Guile. (from the Lightbringer series of books by Brent Weeks)
    Dave
  6. #6
    Senior Member
    AutoCAD 2005
    Dec 2005
    Brandon, Manitoba, Canada
    166
    I don't think you can get autocad to understand just pushing L. But Ctrl+L or Alt+L would definately be possible.
    I'm using 2005 and to customize the key board I go to "Tools" -> "Customize" -> "Keyboard"
    Thalon
  7. #7
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,115
    to answer your question: no (as far as i know, you can't, not the way you're wanting)
    it's simply not how AutoCAD works, without the Spacebar/Enter step. you will just have to adapt. partly the reasoning behind they way it is, is because there are simply tooooo many commands and other things involved to completely take away Spacebar/Enter step when using AutoCAD, even a quarter of the potential.
    and my question is why would you use commands like "Alt+L"?? that seems like even more trouble than the way AutoCAD is defaulted to in the first place, lol. for me to hold Alt and stretch my finger across the keyboard to press L is far more complicated than me hitting L+right-clicking the mouse to execute the LINE command. just my $0.02 - don't take anything the wrong way....
  8. #8
    Full Member
    AutoCAD 2007
    Nov 2006
    33
    hello Stykface,
    thanks for your reply, i am not offended. First, the old right click on the toolbar and customize option seems to be limited, so hot keys can only be reassigned to certain commands. I realise acad is big, real big, but others softwares can do it, and they are bigger. its just for those commands you wish to use often but can never seem to find a quik way. Like explode, you either need to find the toolbar button (more difficult if you run dual monitors) or type expode in the command prompt and then hit enter, would'nt ex + enter be faster? the LINE command is probably not the best example, but by the way, my keboard has 2 ALT buttons!
    Its all in the programming i think. I started my career with acad, worked with it for 4 years, then went to Solidworks and now back to acad. SW is very adaptable in this sort of way and its hard to go back
  9. #9
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,312
    You can assign keyboard shortcuts to any command in Autocad by modifying your acad.pgp file. For instance, you don't have to type the word 'Explode' every time you want to use that tool. I have mine set to just 'X' and then Right Click to initiate. Autocad is just as customizable as any other program.
  10. #10
    Full Member
    AutoCAD 2007
    Nov 2006
    33
    Quote Originally Posted by Cad64 View Post
    Great, how?
  1. Hot keys
    By LSR in forum AutoCAD General
    Last Post: 30th Nov 2007, 07:27 am
  2. Shortcut keys
    By JBS in forum AutoCAD Drawing Management & Output
    Last Post: 10th May 2006, 07:27 pm
  3. customizing keys
    By gortex in forum AutoCAD Drawing Management & Output
    Last Post: 13th Apr 2006, 04:15 pm
  4. Symbols and short cut keys
    By MSAWIN in forum AutoCAD Drawing Management & Output
    Last Post: 30th Mar 2006, 11:58 am
  5. short cut keys
    By jbruno in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Jun 2003, 04:32 pm
