Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Senior Member
    AutoCAD 2014
    Jul 2015
    112
    Smile Bock won't update after processing via lisp
    Greetings every one
    i have a block and i want to scale its subentities by using
    Code:
    (setq acdoc  (vla-get-ActiveDocument (vlax-get-acad-object))
    blocks (vla-get-Blocks acdoc))
    (setq itm (car (entsel)))
    (setq name (vla-get-Name (vlax-ename->vla-object itm)))
    (setq def (vla-item blocks name))
    (setq base (vla-get-Origin def))
    (vlax-for o def (vla-ScaleEntity o base 0.5))
    the routine process only the selected block ... and the other instances of block won't be updated in the drawing unitl i open block editor "bedit" and do some staff there and save and close it
    any suggestions will be appreciated ..
    thanks
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,305
    Is your block dynamic by any chance?
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Senior Member
    AutoCAD 2014
    Jul 2015
    112
    yes it is
    i use this now to do the jop
    Code:
    (COMMAND "-BEDIT" "" blockname)
    (COMMAND "ZOOM" "A")
    (COMMAND "_BCLOSE" "SAVE")
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,635
    Just add this to last line of your original code
    Code:
    (vla-Regen acdoc acActiveViewport)
  5. #5
    Senior Member
    AutoCAD 2014
    Jul 2015
    112
    i use this
    Code:
    (vla-Regen acdoc acAllViewports)
    also with no hope
    these are two blocks with the same scale
    they only get back to their correct scales after opening block editor and save block
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,305
    Quote Originally Posted by handasa View Post
    yes it is
    If a dynamic block reference has dynamic block parameter values which differ from the block definition, then the dynamic block reference will reference an anonymous block definition which contains geometry matching the expected display for the set of dynamic parameter values.
    Therefore, if you wish to scale the objects within every dynamic block reference, you will need to scale the objects within the dynamic block definition, and every anonymous block definition pertaining to the dynamic block.
  7. #7
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,026
    .... and you may lose the control / benefit of these parameters when scaling the related / connected objects unless that Parameter is other than visibility.
  8. #8
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,023
    Quote Originally Posted by Tharwat View Post
    I'm guessing cause there are no methods supported for the parameter object:
    Code:
    _$ (vlax-dump-object (car (vlax-invoke (vlax-ename->vla-object (car (entsel "\nPick dynamic block: "))) 'GetDynamicBlockProperties)) t)
    ; IAcadDynamicBlockReferenceProperty: AutoCAD Dynamic Block Property Interface
    ; Property values:
    ;   AllowedValues (RO) = nil
    ;   Description (RO) = ""
    ;   PropertyName (RO) = "blabla"
    ;   ReadOnly (RO) = 0
    ;   show (RO) = -1
    ;   UnitsType (RO) = 2
    ;   Value = 60.0
    ; No methods
    Therefore ScaleEntity method is not available.
  9. #9
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,026
    Quote Originally Posted by Grrr View Post
    When objects being scaled bigger for instance then objects may get out of the parameter's selection limits, so this should escape objects from the boundary of any parameter other than Visibility since the last one doesn't require any selection.
    Hope this clear enough.
  10. #10
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,023
    Ahh, now I understood what you mean (by visualising how the parameter shall be created from scratch by hand).
  1. Lisp To update the later
    By nannz in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Apr 2017, 06:08 am
  2. Suppression of Command Line Activity During Lisp Processing
    By abra-CAD-abra in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jan 2015, 10:25 am
  3. multi processing... vba Lisp...
    By ibach in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jan 2013, 12:02 pm
  4. Need Lisp to update attributes
    By cabltv1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Feb 2009, 05:50 pm
  5. Hidden bock inserts on hidden layers
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Oct 2006, 06:43 pm
