Results 1 to 3 of 3
    Senior Member
    Construction
    wimal's Discipline Details
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    423
    Default Hatch cannot match properties
    Original hatch found on area A
    With hatch edit hatch created on area B. but why the display scale not same ?
    In properties both hatche scales are same (0.6)
    Senior Member
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    423
    Finally I found the solution. I change the system variable MEASURMENT to 0.
    Senior Member
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    423
    This is finnaly done
  1. Weird hatch problem - match properties does not work
    By pefi in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Dec 2013, 03:46 pm
  2. Match Properties won't match Multileader Text in CAD 2010
    By Sengna in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 27th Sep 2013, 05:10 am
  3. how to match/change the global properties to match an object
    By vickilb in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Nov 2010, 02:10 pm
  4. Copied hatch cannot be match properties
    By ashra in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 29th Oct 2010, 04:26 am
  5. Hatch match properties problem
    By the-trooper in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Aug 2009, 07:13 am
