Results 1 to 3 of 3
    Junior Member
    Map 3D 2010
    Jul 2014
    21
    Default Slight cursor lag - 2018 LT
    I recently purchased the one year subscription for AutoCAD 2018 LT. It’s running on a brand new and somewhat powerful Windows 10 Pro machine.
    I’ve noticed a slight delay in the cursor response whenever I am in paper space and I have a viewport open. Sometimes when I try to move the cursor, with a cabled mouse, it hesitates for a few noticeable milliseconds.
    I’m not a Windows guy, per se, so I don’t know if I have everything configured correctly to take advantage of the hardware. Any help would be greatly appreciated.
    Machine specs:
    Junior Member
    Map 3D 2010
    Jul 2014
    21
    I used Speccy to read the hardware and it seems to be wrong.
    Memory is Crucial at 2400 MHz
    GPU is 11GB not 3
    Odd speccy results.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    Do you have snap on this can do some funny things.
    I take it the mouse is optical put a piece of paper under it some surfaces can cause this also.
  1. AutoCAD 2018.1 and AutoCAD LT 2018.1 Update Now Available
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 28th Jul 2017, 01:10 am
  2. Common designs with slight variations
    By guybrancati in forum AutoCAD Drawing Management & Output
    Last Post: 13th Aug 2008, 03:26 am
  3. slight prob with hatching
    By Vibrance in forum AutoCAD Beginners' Area
    Last Post: 8th Jun 2006, 11:06 pm
  4. slight pause after some cmds in dwgs with attributes
    By trouts in forum AutoCAD Drawing Management & Output
    Last Post: 24th Aug 2005, 06:47 pm
  5. Slight Confusion Over XREF Working Structure
    By hyposmurf in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jan 2004, 07:46 pm
