Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Forum Newbie
    Civil
    AutoCAD 2016
    Sep 2017
    9
    Default Compare 2 lists of entities on equal coordinates
    Hi,
    I want to to compare a list of LWPolyline entities with a list of Circle entities:
    If the LWpolyline end point vertice XY coordinate matches a circle center coordinate XY.
    Then write layer name of circle to new list.
    If not Then return "no match"
    I already have a subroutine which gets the (start) vertices of the LWpolyline.
    Did try a repeat in a repeat...but that didn't work out.
    So I am stucked here, something with mapcar lambda member?
    Can somebody help me how to compare 2 lists
    Greetzzz,
    Gerben
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,026
    Can you write down these two lists or are you after selecting LWpolylines & Circles to check their coordinates out?
    A bit more info is needed.
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    168
    The code below allows you to select a polyline.
    It then checks if there is a circle on its END-point.
    If so, it moves the circle to the layer MATCHLAYER.
    Code:
    (defun C:CadTutor ( / polyline polylinex polyliney allcircles n ensel enlist circlex circley)
    (setq polyline (entget (car (entsel))))
    (setq polylinex (car (cdr (assoc 10 (reverse polyline)))))
    (setq polyliney (car (cddr (assoc 10 (reverse polyline)))))
    (setq allcircles (ssget "_X" (list (cons 0 "CIRCLE"))))
    (setq n (sslength allcircles))
    	(repeat n
    		(setq ensel (ssname allcircles (setq n (1- n))))
    		(setq enlist (entget ensel))
    		(setq circlex (car (cdr (assoc 10 enlist))))
    		(setq circley (car (cdr (cdr (assoc 10 enlist)))))
    		(if (and (= polylinex circlex)(= polyliney circley))
    				(princ "\nMatch found!")
    				(setq enlist (subst (cons 8 "MATCHLAYER") (assoc 8 enlist) enlist))
    				(entmod enlist)
    				(princ "\nNo match...")
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,026
    My attempt.
    Code:
    (defun c:Test ( / int sel ent lst )
      ;; Tharwat - Date: 11.Sep.2017	;;
      (if (and (or (setq int -1 sel (ssget "_X" (list '(0 . "CIRCLE") (cons 410 (getvar 'CTAB)))))
                   (alert "Couldn't find any circle in this drawing <!>")
                 (while (setq ent (ssname sel (setq int (1+ int))))
                   (setq lst (cons (list ent (cdr (assoc 10 (entget ent)))) lst))
                 lst
               (princ "\nSelect LWpolylines to change circles reside on their end points to MatchLayer :")
               (setq int -1 sel (ssget '((0 . "LWPOLYLINE"))))
          (vl-some '(lambda (p)
                      (if (or (equal (vlax-curve-getstartpoint ent) (cadr p) 1e-4)
                              (equal (vlax-curve-getendpoint ent) (cadr p) 1e-4)
                        (entmod (append (entget (car p)) '((8 . "MatchLayer"))))))
                   lst)
      ) (vl-load-com)
  5. #5
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,026
    NOTE: if are there by any chance two circles on start & end points then just replace the function vl-some with mapcar.
  6. #6
    Forum Newbie
    Civil
    AutoCAD 2016
    Sep 2017
    9
    Quote Originally Posted by Tharwat View Post
    My attempt.
    Code:
                 lst
                   lst)
      ) (vl-load-com)
    Thanx man, your code work smooth, however it does not exactly what I want.
    I have changed it a bit to what I want to achieve:
    Code:
          (setq ss2_list nil)
        (setq wtg_id2_lst nil)
        (if
            (and
                (or
                        (setq ss2_list (cons (list ent (cdr (assoc 10 (entget ent)))) ss2_list))
                    ss2_list
                    (cond ((equal (vlax-curve-getendpoint ent) (cadr p) 1e-4)
                                (setq wtg_id2_lst (cons (cdr (assoc 8 (entget (car p)))) wtg_id2_lst))
                            ((/= (vlax-curve-getendpoint ent) (cadr p) 1e-4)
                                ; All circles are on endpoints of LWPOLYLINES
                                ; If any circle is not on any LWPOLYLINE endpoint then break the routine with an alert
                ss2_list)
    (vl-load-com)
    Changes:
    All circles are in separate layers
    Since all circles are (or should be) on LWPOLYLINE endpoints
    I want a Condition that if any LWPOLYLINE Endpoint is equal to any CIRCLE centerpoint, the Circles layer name is written to a list.
    But if not equal then the routine must abort with an alert, because an x amount of circles might be moved by the CAD draftsman during modifications.
    Your " WHILE VL-SOME LAMBDA IF" loop compares 1 LWPOLYLINE ENDpoint with all selected Circles center points...so correct me if I am wrong, if there are lets say 77 circles selected, 76 are not equal to the current LWPOLYLINE ENDpoint. however the other 76 Circles might match other LWPOLYLINE ENDpoints.
    is this possible?
  7. #7
    Forum Newbie
    Civil
    AutoCAD 2016
    Sep 2017
    9
    Hi Tharwat,
    You code runs smooth, however this is not exactly what I want.
    All Circles in my drawing are on seperate layers
    Also All Circles are (or should be) located on LWPOLYLINES ENDpoints (so for now I don't need the startpoint).
    If this is true then the Circles layer name must be written to a list.
    But your While loop compares 1 LWpolyline Endpoint with all Circles centerpoints.
    So if lets say I have 77 circles in the set, 76 of them don't match the endpoint of the current LWPOLYLINE Endpoint in the loop.
    However they do match other LWPOLYLINE endpoints.
    What i want to achieve is that IF any of the LWPOLYLINE Endpoints matches any of the Circles center points THEN write the Circle layer name to a list
    If not then an x amount of the circles are not located on an LWPOLYLINE ENDpoint (some circles might be shifted during modifications by a CAD draftsman) the routine should abort with an alert.
    I have modified your code a bit to show what I want:
    Code:
          (setq ss2_list nil)
        (if
            (and
                (or
                    ss2_list
                                ; All circles are (or should be) on endpoints of LWPOLYLINES
                                ; So If any circle is not on any LWPOLYLINE endpoint then break the routine with an alert
                ss2_list)
    (vl-load-com)
  8. #8
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,026
    Something like this?
    Code:
    (defun c:Test ( / int sel ent lst fnd obj lys)
                    lst
            (while (and (not fnd) (setq ent (ssname sel (setq int (1+ int)))))
               (if (vl-some '(lambda (o) (and (equal (vlax-curve-getendpoint ent) (cadr o) 1e-4) (setq obj o))) lst)
                  (setq lys (cons (cdr (assoc 8 (entget (car obj)))) lys))
                        (setq fnd t)
                        (alert "Found a circle not reside on any end point of a LWpolyline <!>")
        lys
    ) (vl-load-com)
  9. #9
    Forum Newbie
    Civil
    AutoCAD 2016
    Sep 2017
    9
    Wow, works like a charm! thanx
    Few questions about it:
    1. What does the (not fnd) and (setq fnd t) in the code? When I put a semicolon before them, I still get the same result
    2. same for lst after the while statement and lys after the if statement?
  10. #10
    Forum Newbie
    Civil
    AutoCAD 2016
    Sep 2017
    9
    Is it possible to catch the circle object, which not resides on any end point of LWPOLYLINE, in a variable?
  1. Create two lists of strings, and compare them to each other...?
    By lamensterms in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Sep 2015, 08:25 am
  2. Conversion of coordinates entities
    By jevrem1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Apr 2015, 02:51 pm
  3. Lisp to import coordinates for various AutoCAD entities
    By meric_u2003 in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th May 2013, 07:59 am
  4. Divide a polyline at equal intervals and extract coordinates in excel
    By symoin in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jun 2011, 09:10 am
  5. autolisp routine to read coordinates and insert entities points
    By teknomatika in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Sep 2010, 06:51 pm
