+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Forum Newbie
    Using
    AutoCAD 2013
    Join Date
    May 2013
    Posts
    2
    Default Text rotates in MTEXT while editing
    Hi all, whenever I enter the MTEXT editing function, then type a letter on any given line of text, that line rotates to the world UCS. This makes typing almost impossible, as the overlapping text can't be read clearly.
    Any suggestions?
    I'm using AutoCAD 2013 for Mac and looking at my drawing with a rotated UCS.
  2. #2
    Luminous Being Dadgad's Avatar
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    5,995
    Default
    Welcome to CADTutor.
    I have not used CAD on a MAC, but the image may shed some light on your
    situation. I have used the SYSVDLG command to access the variable dialog box,
    which may or may not be available on a MAC.
    Volume and repetition do not validate opinions forged in the absence of thought.
  3. #3
    Forum Newbie
    Using
    AutoCAD 2013
    Join Date
    May 2013
    Posts
    2
    Default
    Thanks for your input, Dagdad. I've tested every configuration of both the MTEXTED and MTEXTFIXED variables to no avail. The text still rotates during editing.
    One other note: this is only happening to drawings saved before today. New drawings to do not attract the same problem.
  4. #4
    Forum Newbie
    Using
    Civil 3D 2015
    Join Date
    Sep 2014
    Posts
    6
    Default
    I have noticed 1 other factor in this scenario that I fought for 2years before I figured it out. The Mleader was created while a certain linetype was being used, set linetype to continuous and fixed. Set mtextfixed to 2. I have only had this problem with mleaders though, not just a mtext.
  5. #5
    Forum Newbie
    Discipline
    Surveying
    Using
    Land Desktop 2009
    Join Date
    Sep 2017
    Posts
    2
    Default
    I have the exact same problem that the original post describes. Have you found a solution?
    I'm using AutoCAD Land Desktop 2009
  6. #6
    Forum Newbie
    Using
    Civil 3D 2015
    Join Date
    Sep 2014
    Posts
    6
    Default
    I have only encountered this problem while a linetype other than continuous was applied to the MTEXT or Mleader, If I changed the linetype in the properties it corrects the problem. I have my MTEXTED set to "internal" & MTEXTFIXED set to 2.
  7. #7
    Forum Newbie
    Discipline
    Surveying
    Using
    Land Desktop 2009
    Join Date
    Sep 2017
    Posts
    2
    Default
    Chris thanks for your reply. I got excited and checked the mtext but there was no linetype applied. But just now I may have found a solution! While editing the text I clicked on the little button on the right for options and go down to "Editor Settings" and toggle on "Always Display as WYSIWYG" and now it is editing normally. I hope that solution sticks!
Similar Threads
  1. MTEXT editing
    By jitu in forum AutoCAD Drawing Management & Output
    Last Post: 21st Nov 2014, 10:24 am
  2. Does anyone know why when I create a DWF it rotates the text in my titleblock?
    By drue in forum AutoCAD Drawing Management & Output
    Last Post: 26th Aug 2010, 04:25 pm
  3. Text Rotates back to original UCS when printing from Paperspace
    By geocad in forum AutoCAD Beginners' Area
    Last Post: 25th Feb 2009, 03:52 pm
  4. Mtext editing
    By The Alpine Cow in forum AutoCAD General
    Last Post: 11th Nov 2008, 01:51 am
  5. Trying to plot, but text rotates
    By Shiloh in forum AutoCAD Drawing Management & Output
    Last Post: 20th Apr 2008, 09:02 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
