+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Full Member
    Discipline
    Manufacture
    neondeon298's Discipline Details
    Occupation
    CAD Specialist / NDT
    Discipline
    Manufacture
    Using
    AutoCAD 2017
    Join Date
    Dec 2016
    Posts
    34
    Default Side Drilled Hole in Pipe Ellipse
    So I have a Top View and Side View of a pipe. The pipe is cut in half. The pipe has a small diameter drill hole that looks like straight lines on the Side View. On the top view I know this drilled hole would give the illusion of an ellipse (better yet an egg shape). How do you guys draw such an egg shape? I have attached an image. Red Cloud is showing the ellipse I am having issues with.Side Drill Hole Ellipse.jpg
  2. #2
    Full Member
    Discipline
    Manufacture
    Occupation
    Discipline
    Manufacture
    Using
    AutoCAD 2017
    Join Date
    Dec 2016
    Posts
    34
    Default
    I may have gotten it. Instead of using of using the center of the 2 hole sides I found the virtual between the 2 yellow lines. It was slightly lower and put the ellipse centered properly. However, am I wrong in assuming that it wouldn't make ellipse but an egg shape?
  3. #3
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,363
    Default
    You could always test that assumption by recreating the object in 3D. It would take but a minute to do. The beauty of this method is that you could then extract the 2D view directly from the model using the FLATSHOT command. BTW...I ran a quick test myself using the method I outlined. It does work. Try it yourself. We can compare results.
  4. #4
    Full Member
    Discipline
    Manufacture
    Occupation
    Discipline
    Manufacture
    Using
    AutoCAD 2017
    Join Date
    Dec 2016
    Posts
    34
    Default
    I don't know why I didn't think of just look at 3D. I was already making a 3D model (it was quitting time I guess). But yet another command (Flatshot) that I was unawares. My assumption was correct that there is just slightly an egg shape to the holes when viewed from top. Did you have the same results? Thank you so much!
  5. #5
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,363
    Default
    Here's what I got. The 3D model is on the left and the 2D flatshot view on the right.
  6. #6
    Full Member
    Discipline
    Manufacture
    Occupation
    Discipline
    Manufacture
    Using
    AutoCAD 2017
    Join Date
    Dec 2016
    Posts
    34
    Default
    I guess long tear drop shape is better described then egg shaped lol
Similar Threads
  1. Ellipse right side view?
    By Sengna in forum AutoCAD Beginners' Area
    Last Post: 1st Sep 2015, 06:11 pm
  2. Punching a Hole in the side of a plate
    By gbradley in forum Autodesk Inventor
    Last Post: 16th Aug 2015, 12:02 pm
  3. 3D Pipe Elbow - Ellipse to Circle
    By ORBIMAT123 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th May 2011, 09:21 am
  4. Drilled Hole
    By CAD<LIFE in forum AutoCAD Beginners' Area
    Last Post: 24th Apr 2007, 03:03 am
  5. Placing a hole on the side of a cylinder - Inventor
    By amirintisar in forum Tutorials & Tips'n'Tricks
    Last Post: 5th Mar 2006, 09:13 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
