+ Reply to Thread
Results 1 to 10 of 10
  1. #1
    Junior Member
    Computer Details
    harrydang's Computer Details
    Operating System:
    Wins 10
    Computer:
    DELL
    Discipline
    Electrical
    Using
    AutoCAD 2010
    Join Date
    Sep 2017
    Location
    Sydney, Australia
    Posts
    20
    Default line type change
    Hello guys,
    I working on AutoCAD 2010. And for some reasons, some line types have changed as shown in the attachments (linetype scale, lineweight, and thickness are not changed). Could you please tell me why and how to fix this issue? Much appreciated!
  2. #2
    Forum Deity
    Using
    AutoCAD 2002
    Join Date
    Sep 2006
    Location
    East Sussex, U.K.
    Posts
    4,058
    Default
    These linetypes use a letter in their definition. These letters have a Textstyle associated with them. For ease of use, the textstyle used is usually Standard, because it automatically exists in every drawing.
    My thoughts are that the Standard textstyle has got different fonts in your drawings. Change to a common font and your linetypes will appear the same.
  3. #3
    Super Member CyberAngel's Avatar
    Computer Details
    CyberAngel's Computer Details
    Operating System:
    Windows 10
    Discipline
    Architectural
    CyberAngel's Discipline Details
    Occupation
    Civil Drafter
    Discipline
    Architectural
    Details
    Roofing and Waterproofing
    Using
    AutoCAD 2014
    Join Date
    Jul 2006
    Location
    Anywhere Else
    Posts
    1,138
    Default
    Don't forget that, whenever you bring an entity with the Standard font into a drawing, its definition overrides the previous one. You may have changed Standard without realizing it. One solution is to include an initialization routine that replaces the current definition with your default. Another is to redefine your linetypes.
    breaking AutoCAD on a regular basis since 1991
  4. #4
    Junior Member
    Computer Details
    Operating System:
    Wins 10
    Computer:
    DELL
    Discipline
    Electrical
    Using
    AutoCAD 2010
    Join Date
    Sep 2017
    Location
    Sydney, Australia
    Posts
    20
    Default
    Hi Eldon,
    Thanks for getting back to me. These linetypes are created as standards and I just copied and pasted for convenient use. I also bring some blocks from other drawings into mine. Before doing that, I purged all the items, which I guess causes a conflict between two drawings.
    I have changed all the textstyle (text and Mtext) to standard but it does not help. Would there be anything I overlooked?
    Thank you
  5. #5
    Junior Member
    Computer Details
    Operating System:
    Wins 10
    Computer:
    DELL
    Discipline
    Electrical
    Using
    AutoCAD 2010
    Join Date
    Sep 2017
    Location
    Sydney, Australia
    Posts
    20
    Default
    Hi CyberAngel,
    Yes, I have brought some other blocks to my drawing and I guess these different standard might lead to a conflict.
    Regarding the 1st solution, I have done a massive work on the drawing and I do not want to redo it. (did not know which steps changed the definition)
    For the 2nd solution, can you please teach me how to redefine the linetypes. (Sorry I am brandnew. )
    Many thanks
  6. #6
    Forum Deity
    Using
    AutoCAD 2002
    Join Date
    Sep 2006
    Location
    East Sussex, U.K.
    Posts
    4,058
    Default
    Quote Originally Posted by harrydang View Post
    Hi Eldon,
    Thanks for getting back to me. These linetypes are created as standards (?) and I just copied and pasted for convenient use. I also bring some blocks from other drawings into mine. Before doing that, I purged all the items, which I guess causes a conflict between two drawings.
    Thank you
    The actual font used for the Standard textstyle is all important. Each individual font has its own points of insertion for the different characters. So in the linetype definition, the x and y factors only apply to the font used, and will be different for a different font.
    Go into the Text Style manager and see what font name has been used, and make these the same for both drawings.
    Blocks have no effect and purging has no effect, but the specific font used for the Standard Text Style does have effect.
    If you want to use a different font, then you will have to edit the linetype definition file.
  7. #7
    Junior Member
    Computer Details
    Operating System:
    Wins 10
    Computer:
    DELL
    Discipline
    Electrical
    Using
    AutoCAD 2010
    Join Date
    Sep 2017
    Location
    Sydney, Australia
    Posts
    20
    Default
    Quote Originally Posted by eldon View Post
    Finally, I am with you now. I have changed text height to 2.5 (meant to be 0.00). Now, everything comes back to normal.
    Thank you so much Eldon
  8. #8
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO 64-bit
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    Pentium(R) i5 4570 @ 3.2GHz
    RAM:
    8 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    11,821
    Default
    I have moved your thread to the The CUI, Hatches, Linetypes, Scripts & Macros Forum.
  9. #9
    Super Member
    Computer Details
    tombu's Computer Details
    Operating System:
    Windows 7 64-bit
    Computer:
    Dell
    Discipline
    Civil
    tombu's Discipline Details
    Occupation
    Design Analyst
    Discipline
    Civil
    Details
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Using
    Civil 3D 2018
    Join Date
    Dec 2010
    Location
    Tallahassee, FL USA
    Posts
    735
    Default
    The issue for these linetypes can easily be avoided by not using Text Styles:
    Code:
    *FENCE, Fence -per FDOT's AUTOCAD Users Supplement---- X ---- X ---- X ---- X ---- X ----
    ;A,.5,-.025,[TRACK1,ltypeshp,a=135,s=.08],0,[TRACK1,ltypeshp,a=45,s=.08],-.025,.5
    A,.5,-.025,[TRACK1,ltypeshp,r=135,s=.08],0,[TRACK1,ltypeshp,r=45,s=.08],-.025,.5
    *LARW,Limited Access R/W -per FDOT's AUTOCAD Users Supplement ----- / - / - / ----- / - / - / -----
    A,.635,-.035,[TRACK1,ltypeshp,r=150,s=.06],-.04,.15,-.035,[TRACK1,ltypeshp,r=150,s=.06],-.04,.15,-.035,[TRACK1,ltypeshp,r=150,s=.06],-.04
    ltypeshp shp & shx files are included with every AutoCAD install.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  10. #10
    Super Member
    Computer Details
    Operating System:
    Windows 7 64-bit
    Computer:
    Dell
    Discipline
    Civil
    Occupation
    Design Analyst
    Discipline
    Civil
    Details
    Using
    Civil 3D 2018
    Join Date
    Dec 2010
    Location
    Tallahassee, FL USA
    Posts
    735
    Default
    To use complex linetypes with text without issues never reference the Standard text style as it could be any font. Create both text style names and lin files that match the font used. I keep all my lin files in my Roamable Support Folder so while the default is acad.lin when I click [Load…] in the Linetype Manager I can select any of my lin files like Arial.lin by clicking [File…].
    You have to remember to add the matching text style first, I have a drop-down in my Ribbon for adding text styles to make it simple.
    Code:
    ; Add New Text Style by Tom Beauford
    (defun NewStyle (TxtStyle Font / acadApp acadDoc styles objStyle FType)
      (setq acadApp (vlax-get-Acad-object)
            acadDoc (vla-get-ActiveDocument acadApp)
            styles (vla-get-textstyles acadDoc)
            objStyle (vla-add styles TxtStyle)
            FType (vl-filename-extension Font)
      (if(= ".ttf" FType)(setq Font (strcat "C:\\Windows\\Fonts\\" Font)))
      (setq Font (findfile Font))
      (princ "\nFont = ")(princ Font)(princ)
      (vla-put-fontfile objStyle Font)
    ;^C^C^P(or NewStyle (load "NewStyle.lsp"))(or(tblsearch "style" "Romans")(NewStyle "Romans" "romans.shx"))
    ;^C^C^P(or NewStyle (load "NewStyle.lsp"))(or(tblsearch "style" "Simplex")(NewStyle "Simplex" "simplex.shx"))
    ;^C^C^P(or NewStyle (load "NewStyle.lsp"))(or(tblsearch "style" "Arial")(NewStyle "Arial" "arial.ttf"))
    ;^C^C^P(or NewStyle (load "NewStyle.lsp"))(or(tblsearch "style" "Arial Bold")(NewStyle "Arial Bold" "arialbd.ttf"))
    ;^C^C^P(or NewStyle (load "NewStyle.lsp"))(or(tblsearch "style" "Arial Narrow")(NewStyle "Arial Narrow" "arialn.ttf"))
    ;^C^C^P(or NewStyle (load "NewStyle.lsp"))(tblsearch "style" "Swiss Lt BT")(NewStyle "Swiss Lt BT" "swissl.ttf"))
Similar Threads
  1. Line type change in the selected blocks
    By kite15 in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Apr 2016, 01:16 pm
  2. Line Type Will Not Change
    By gsksun4 in forum AutoCAD LT
    Last Post: 3rd Oct 2014, 01:48 pm
  3. Break the line and change the line type
    By nalsur8 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jul 2011, 02:12 pm
  4. Line type scales change.... BIG PROBLEM
    By RICO in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 25th May 2011, 07:28 am
  5. Can't change line type, need some help guys.
    By T.A. Metal in forum AutoCAD Beginners' Area
    Last Post: 3rd Nov 2008, 05:08 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
