Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    Senior Member
    AutoCAD 2010
    Jun 2012
    350
    Default Position of point with respect to a line
    Hello everybody,
    I have three points A(x1,y1), B(x2, y2) and C(x3, y3). How can I find which side C is when looked from A to B. That is whether point C is on the left or right of line AB by a calculation with the coordinates of the three points.
    Thanks in advance.
    Aloy
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,026
    Hi Aloy,
    Please try this.
    Code:
    (and (setq a (getpoint "\nSpecify point A :"))
         (setq b (getpoint "\nSpecify point B :" a))
         (setq c (getpoint "\nSpecify point C :"))
         (alert (strcat "Point resides on the " (if (minusp (sin (- (angle a b) (angle a c)))) "Left" "Right") " Side."))
    Senior Member
    AutoCAD 2010
    Jun 2012
    350
    Thanks Tharwat. Actually I wanted the three points to be assigned by a program to handle area calculations automatically for cut and fills in earthworks. I think I can make use of the last line.
    Thanks again.
    Aloy
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,635
    There is a also a vector answer similar to Tharwat solution I know I used it but am struggling to find it, uses x & y
    Found an example it returns a + or - answer. Now to find my lisp version.
    Code:
    (p2.X-p1.X)*(p3.Y-p1.Y)-(p2.Y-p1.Y)*(p3.X-p1.X)
  5. #5
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,026
    Quote Originally Posted by aloy View Post
    Thanks again.
    Aloy
    You are welcome Aloy and good luck.
  6. #6
    Senior Member
    AutoCAD 2010
    Jun 2012
    350
    Hi Bigal,
    I found similar vector cross product thing when I searched. But I thought it is too long. Besides it involves determinants and transpose etc. Thanks for pointing out.
    Aloy
  7. #7
    Senior Member
    AutoCAD 2010
    Jun 2012
    350
    Hi Tharwat,
    It works very nicely. I will post the code and the drawing that was generated for working out the areas of cuts and fills auomatically.
    Here x2 is point of intersection at the end of cut or fill, q3 is A, q4 is B and pz is C. It gave me the sum of two cuts and one fill. You saved lot of time for me.
    Aloy
    Code:
    (if x2 (progn (setq i2 (angle q3 q4)) (setq i3(angle q3 pz))))
        (if (and x2 (and (> (sin (- i2 i3)) 0.0))) (setq fill (+ fill a)))
        (if (and x2 (and (< (sin (- i2 i3)) 0.0))) (setq cut (+ cut a)))
  8. #8
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,305
    Here's another way, using the vector cross product:
    Code:
    (defun c:test ( / a b c )
        (if (and (setq a (getpoint "\n1st point of line: "))
                 (setq b (getpoint "\n2nd point of line: " a))
                 (setq c (getpoint "\nPoint to test: "))
            (LM:clockwise-p a c b)
    ;; Clockwise-p - Lee Mac
    ;; Returns T if p1,p2,p3 are clockwise oriented
    (defun LM:clockwise-p ( a b c )
        (apply '> (mapcar '* (mapcar '- c a) (reverse (mapcar '- b a '(0 0)))))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  9. #9
    Senior Member
    AutoCAD 2010
    Jun 2012
    350
    Thanks LM. I will try this also. I am sure it would work. Pretty difficult to understand the last line though.
  10. #10
    Forum Newbie
    not applicable
    Jan 2010
    1
    give this a try
    Code:
    ;determines the orientation on the basis of pointaxis P1 -> P2
    ;Points in current UCS
    ;example function:
    ;(setq
    ;  pt1 (getpoint "\nfirst point: ")
    ;  pt2 (getpoint "\nsecond point: " pt1)
    ;(while
    ;  (/= (car (setq pt3 (grread 'T 1 0))) 3)
    ;  (if (leftright-p pt1 pt2 (cadr pt3))
    ;    (princ "\nyou are left: ")
    ;    (princ "\nyou are right: ")
    ;returns T=left nil=right
    (defun leftright-p
      ( pt1 pt2 pt3 /
        area
      (setq area
          (- (* (car pt1) (cadr pt2)) (* (cadr pt1) (car pt2)))
          (- (* (cadr pt1) (car pt3)) (* (car pt1) (cadr pt3)))
          (- (* (car pt2) (cadr pt3)) (* (car pt3) (cadr pt2)))
      (and
        (> area 0)
        (not (equal area 0 0.0000001))
  1. Replies: 63
    Last Post: 27th Jun 2016, 11:35 pm
  2. Lisp to determine position of blocks respect to a reference block
    By sadhu in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Mar 2013, 01:36 am
  3. How to position a sketch plane at the end of a line
    By KarolR in forum Autodesk Inventor
    Last Post: 20th Sep 2012, 02:48 pm
  4. Trim to a point or cursor position
    By czyktech in forum AutoCAD Beginners' Area
    Last Post: 11th Dec 2008, 01:45 am
  5. The leader line adjusts its position when I place it
    By Siberian in forum AutoCAD General
    Last Post: 26th Aug 2008, 10:13 am
