Results 1 to 10 of 10
    Forum Newbie
    satydevNegi's Computer Details
    Windows
    HP Lap Top
    4GB
    Civil
    satydevNegi's Discipline Details
    Civil Engineer Power Industry
    Civil
    Currently I am working as Site Engineer but I use to Make structural Design also using STAAD Pro
    AutoCAD 2015
    Sep 2017
    Noida, India
    4
    Default Lisp for getting spot levels
    Hi
    This is my first post and I am untrained LISP user. I am currently using LISPfile to obtain spot levels from Auto CAD then open the file in Excel to calculate cutting and filling quantities. The coding is following.
    Code:
    (defun c:aaaa()
           (setq ptu(getpoint "Enter Upper point   :")
                 ptl(getpoint "Enter Lower point   :")
                 ss_1(ssget "_C" ptu ptl)
                 ss_1(ssget "P" '((0 . "text")))
                 len (sslength ss_1)
                 cnt 0
                 f (open "ten04.txt" "a")
              (while (>= len cnt)
                 (setq ent1 (ssname ss_1 cnt)
                  ent2 (entget ent1)
                  ent3 (assoc 1 ent2)
                  ent3 (cdr ent3)
                  (write-line ent3 f)
                     (setq cnt (1+ cnt))
    (close f)
    Since in this file I ave used two points so I use Excel to repeat my command to obtain data quickly the excel file codes are as follows
    aaaa
    378102575.75,2624684164.103 378127575.75,2624709164.103
    aaaa
    378127575.75,2624684164.103 378152575.75,2624709164.103
    aaaa
    378152575.75,2624684164.103 378177575.75,2624709164.103
    aaaa
    378177575.75,2624684164.103 378202575.75,2624709164.103
    aaaa
    378202575.75,2624684164.103 378227575.75,2624709164.103
    aaaa
    378227575.75,2624684164.103 378252575.75,2624709164.103
    please help me to modify this file
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    11,669
    Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
    Senior Member Jef!'s Avatar
    AutoCAD 2008
    Sep 2010
    228
    Hi satydevNegi, welcome to the forum.
    If in your selection set you have 2 items (lets say A & B) the var len correspond to the qty of items in your selection set (2). When you manipulate the selection set you retrieve the items by their index number using (ssname indexnumber). The index start at 0.
    item A > ssname 0
    item B > ssname 1
    That is why the cnt is initially set at 0. After retrieving the item, you increment the counter cnt.
    If the while condition is (>= len cnt), when cnt is 2, same as len, since len is bigger or equal to cnt, it keeps going, trying to retrieve (ssname 2) which corresponds to the 3rd element of the selection set, and it does not exist. Your while condition should be (> len cnt).
    I'm not sure what exactly you were asking for, and if what I mentioned is the only thing preventing you to get the desired result. I would also strongly suggest that you localize variables... and that you enclose your code in code tags.
    If you need further assistance, try to be as clear as possible as what your goal is.
    Cheers
    Different goal also quite often means different path...
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,635
    An easier way and I tend do it it now this way is to use repeat rather than while and it takes into account the zero item
    [code]
    (repeat (set x (sslength ss_1))
    (setq ent1 (ssname ss_1 (setq x (- x 1))) ; auto goes down to zero
  5. #5
    Forum Newbie
    Windows
    HP Lap Top
    4GB
    Civil
    Civil
    AutoCAD 2015
    Sep 2017
    Noida, India
    4
    Hi Jef!
    please tell me if this is useful tool or not,
    I use local variables if i have to make something in auto cad, but here i have to export texts from and not sure if i can do use local variables.
    i feell my communication is not exactly up to mark.
  6. #6
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    706
    Quote Originally Posted by satydevNegi View Post
    As the texts are saved in a text file I don't see any reason to keep the values of ptu, ptl, ss_1, len, cnt, f, ent1, ent2, or ent3. I'd localize all those variables. They would all be reset if you ran the lisp again anyway.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  7. #7
    Forum Newbie
    Windows
    HP Lap Top
    4GB
    Civil
    Civil
    AutoCAD 2015
    Sep 2017
    Noida, India
    4
    Quote Originally Posted by tombu View Post
    Thank you all for making me understandable about local and global variables. Here i have added modified version just addressing local variables in it . but my worry is still pending here , I want to make the selection process in a way so that we can use this route in multiple times (Looping) for multiple selection sets without typing aaaa many times. Please correct me if my communication does not reach to you.
    Code:
    ;;;;Hi this Lisp is written for exporting texts
    ;;;;having values of ground levels so that
    ;;;;calculations of earth cutting / filling can
    ;;;;be obtained. For that type aaaa in Autocad
    ;;;;command prompt switch off osnap,
    ;;;;for making lisp short I skip that variable
    ;;;;pick lower and upper corner in autocad where
    ;;;;the text you need to export for the purpose
    ;;;;you will get a file textofspotlvl in your
    ;;;;working directory open that file in your
    ;;;;excel software and use
    (defun c:aaaa( / ptu ptl ss_1 len cnt f ent1 ent2 ent3);command aaaa
           (setq ptu(getpoint "Enter Upper point   :");for making selection
                 ptl(getpoint "Enter Lower point   :");of texts
                 ss_1(ssget "_C" ptu ptl);variable for selection set
                 len (sslength ss_1);number of texts
                 cnt 0;counter starts
                 f (open "textofspotlvl.txt" "a");making external file
           );close setq
              (while (>= len cnt);looping
                 (setq ent1 (ssname ss_1 cnt);assitant to entget
                  ent2 (entget ent1);for gettingg value of spot level
                  ent3 (assoc 1 ent2); separating spot level
                  ent3 (cdr ent3)
                 );close setq
                  (write-line ent3 f) ;exported
                     (setq cnt (1+ cnt))counter for other texts
              );closee loop
    (close f);close file
    (princ);cleaning memory
    );close defun
  8. #8
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    11,669
    This will be your last warning. Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
  9. #9
    Forum Newbie
    Windows
    HP Lap Top
    4GB
    Civil
    Civil
    AutoCAD 2015
    Sep 2017
    Noida, India
    4
    Quote Originally Posted by SLW210 View Post
    Code:
    Your Code Here
    Dear Super Moderator
    I am trying to correct my mistake, expect one more chance
    Code:
    );close setq
    ent3 (cdr ent3)
    );close setq
    );closee loop
    );close defun
  10. #10
    AutoCAD 2008
    Sep 2010
    228
    Hi Jef!
    it might... we are not far. The thing we will have to do is put the while inside another while... BUT for that to work you need to start by fixing what I talked about in my previous post. There is absolutely no way we can make it work if you try to process more entities in the selection set then what it contains. You will end up with an error: bad argument type: lentityp nil
    Not only that but when you added the comments on your last edit, you forgot to add a semicolumn ";" in front of the comment "counter for other texts".
    Fix these 2 issues and post the code back (with code tags), and I will gladly help you with the last step.
    Cheers
  1. LSP, LISP grade levels, point calculation, road levels
    By nosyparker in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Oct 2014, 09:02 am
  2. drawing points from flattened spot levels
    By stupot in forum AutoCAD General
    Last Post: 8th Mar 2012, 04:51 pm
  3. Spot levels
    By paulrfair in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Feb 2012, 01:06 am
  4. Plotting contours from randoml placed spot levels
    By JamesP in forum AutoCAD Beginners' Area
    Last Post: 13th Jun 2009, 02:56 pm
  5. Spot Levels
    By mdmmike in forum AutoCAD General
    Last Post: 7th Aug 2007, 04:52 pm
Tags for this Thread
