Results 1 to 7 of 7
    Junior Member leo321's Avatar
    leo321's Computer Details
    w7 64bt
    TOSHIBA / DELL
    i5 3°generation
    4 gb other 6gb
    1gb other 2gb
    500gb
    2 tera
    21' and 17'
    Structural
    leo321's Discipline Details
    design Project
    Structural
    Pipelines, Industrials Units, Wind Farms, Minig, transmission line, thermoelectric, etc..
    AutoCAD 2012
    Jan 2013
    São Paulo / Brazil
    21
    Default help! Masters; EXTRACT VERTEX X,Y choose first point at way clockwise (need upgrade)
    I had this from Lee, but usually always go way counter-clockwise and only select the polyline, not the point.
    ;; Polyline Vertex Exporter ~ by Lee McDonnell ~ 26.11.2009
    (defun c:pExp2 (/ ss tmp i j ent tot dis pt)
    (vl-load-com)
    (if (and (setq ss (ssget '((0 . "*POLYLINE"))))
    (setq tmp (getfiled "Output File" (cond (*load) ("")) "txt;csv" 9)))
    (setq *load tmp tmp (open tmp "a") i -1)
    (write-line "X,Y,Layer" tmp)
    (while (setq ent (ssname ss (setq i (1+ i))))
    (setq tot 0. j (1- (vlax-curve-getStartParam ent)))
    (while (<= (setq j (1+ j)) (vlax-curve-getEndParam ent))
    (setq pt (mapcar 'rtos (vlax-curve-getPointatParam ent j)))
    (write-line
    (strcat (car pt) (chr 44) (cadr pt) (chr 44) (vla-get-layer (vlax-ename->vla-object ent)))
    tmp))
    (write-line "" tmp))
    (close tmp)))
    (princ))
    THX for any tips.
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    Wow, that's some old code...
    I don't quite understand, what do you want the code to do?
    PS: Please edit your post and enclose your code with code tags:
    [code]Your code here[/code]
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    w7 64bt
    TOSHIBA / DELL
    i5 3°generation
    4 gb other 6gb
    1gb other 2gb
    500gb
    2 tera
    21' and 17'
    Structural
    design Project
    Structural
    AutoCAD 2012
    Jan 2013
    São Paulo / Brazil
    21
    I´ll try explian;
    the file returns the polyline reverse clockwise way sample;
    X,Y,Layer
    485172.23,6691696.77,FC 0059
    485157.93,6691697.48,FC 0059
    485156.58,6691666.50,FC 0059
    485171.15,6691665.78,FC 0059
    I would like th clockwise side return, (above)
    If can select the FIRST vertex it will be perfect;
    take this oportunite to say I follow this years, your are the guy, congrates
    sorry for my bad english
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    Thank you for your compliments
    Please try the following:
    Code:
    (defun c:ptx ( / *error* des ent enx lay lst txt )
        (defun *error* ( msg )
            (if (= 'file (type des)) (close des))
            (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
        (if (setq txt (getfiled "Create Output File" (cond ( ptx:dir ) ( "" )) "txt;csv" 1))
            (while
                (not
                    (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect 2D polyline <Done>: ")))
                        (cond
                            (   (= 7 (getvar 'errno))
                                (prompt "\nMissed, try again.")
                            (   (null ent))
                            (   (/= "LWPOLYLINE" (cdr (assoc 0 (setq enx (entget ent)))))
                                (prompt "\nThe selected object is not a 2D polyline.")
                            (   (not
                                    (or des
                                        (and (setq des (open txt "w"))
                                             (setq ptx:dir (strcat (vl-filename-directory txt) "\\"))
                                             (write-line "X,Y,Layer" des)
                                (princ (strcat "\nUnable to open \"" txt "\" for writing."))
                            (   (setq lst (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (= 10 (car x))) enx))
                                      lay (list "," (strcat "," (cdr (assoc 8 enx))))
                                (foreach vtx (if (LM:listclockwise-p lst) lst (reverse lst))
                                    (write-line (apply 'strcat (mapcar 'strcat (mapcar 'rtos vtx) lay)) des)
                                (write-line "" des)
                                (prompt (strcat "\n" (itoa (length lst)) " vertices written to " (vl-filename-base txt) (vl-filename-extension txt) "."))
            (princ "\n*Cancel*")
        (*error* nil) (princ)
    ;; List Clockwise-p - Lee Mac
    ;; Returns T if the point list is clockwise oriented
    (defun LM:listclockwise-p ( lst )
        (minusp
            (apply '+
                (mapcar
                    (function
                        (lambda ( a b )
                            (- (* (car b) (cadr a)) (* (car a) (cadr b)))
                    lst (cons (last lst) lst)
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    And another, allowing optional selection of a start point:
    Code:
    (defun c:ptx ( / *error* cnt des dis ent enx idx lay lst spt tmp txt )
            (while
                (not
                        (cond
                            (   (null ent))
                            (   (not
                                    (or des
                                      lst (if (LM:listclockwise-p lst) lst (reverse lst))
                                (if (setq spt (getpoint "\nSpecify start point <use first vertex>: "))
                                        (setq idx 0
                                              cnt 1
                                              spt (trans spt 1 ent)
                                              dis (distance spt (car lst))
                                        (foreach pnt (cdr lst)
                                            (if (< (setq tmp (distance spt pnt)) dis)
                                                (setq dis tmp
                                                      idx cnt
                                            (setq cnt (1+ cnt))
                                        (repeat idx (setq lst (append (cdr lst) (list (car lst)))))
                                (foreach vtx lst
                                (write-line "" des)
        (minusp
            (apply '+
                (mapcar
                    (function
                        (lambda ( a b )
  6. #6
    w7 64bt
    TOSHIBA / DELL
    i5 3°generation
    4 gb other 6gb
    1gb other 2gb
    500gb
    2 tera
    21' and 17'
    Structural
    design Project
    Structural
    AutoCAD 2012
    Jan 2013
    São Paulo / Brazil
    21
    Thanks a lot, when come to Brazil your beer is guarantees, it´ll be a honor.
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
  1. lisp needed : extract poly line vertex X,Y into txt file
    By ayman_48 in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th May 2018, 05:54 am
  2. closest vertex to a point an polyline
    By HARRY-PLOTTER in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Jan 2014, 03:51 pm
  3. Choose a useful point style in AutoCAD
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 26th Nov 2012, 01:10 am
  4. Replies: 17
    Last Post: 6th Apr 2012, 07:57 pm
  5. Block to a certain point or to a vertex
    By JORYROJ in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Oct 2011, 12:48 pm
Tags for this Thread
