+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Forum Newbie
    Discipline
    Civil
    Using
    AutoCAD 2016
    Join Date
    Sep 2017
    Posts
    2
    Default how repeat Arc (Center , start , end ) Command without select From Draw tab?
    hello my frieand , how can i repeat Arc (Center , start , end ) Command without select From Draw tab?
    i have problem with this Command when i want to use Continuous, everytime i Should select again from Draw Pannel of Home Tab for use again!
    ( i want to use this like move command , for ex : select move & use that , Click Enter and use again from Move ) but in the Arc Command when u Click enter , autocad select Arc whit 3 Points!
  2. #2
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO 64-bit
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    Pentium(R) i5 4570 @ 3.2GHz
    RAM:
    8 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2018
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    11,888
    Default
    If you hit C after starting the Arc command it goes to the Center, Start, End.
    You need to watch the Commandline.
    Code:
    Command:
    ARC Specify start point of arc or [Center]: c
    Specify center point of arc:
    Specify start point of arc:
    Specify end point of arc or [Angle/chord Length]:
  3. #3
    Forum Newbie
    Discipline
    Civil
    Using
    AutoCAD 2016
    Join Date
    Sep 2017
    Posts
    2
    Default
    I know how it draw! but i want to draw again after use this command with ENTER click! i want select this command again , without select arc with 3 point!
  4. #4
    Computer Details
    Operating System:
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    RAM:
    8 GB RAM
    Graphics:
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2018
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    11,888
    Default
    Takes a fraction of a second to hit Enter, C. You asked for a method to do this without using the draw tab and I gave you that.
    If that's not what you want, you need to give a better explanation.
  5. #5
    Super Member bjenk8100's Avatar
    Computer Details
    bjenk8100's Computer Details
    Operating System:
    windows 8 64 bit
    Discipline
    Construction
    Using
    AutoCAD 2018
    Join Date
    Sep 2009
    Posts
    622
    Default
    keep things simple. repeat a command with enter and look at command line area for options. im proud to say i only use ribbons when i am ready to annotate. if all else fails properties panel
Similar Threads
  1. stop automatically repeat select comand
    By sergiu_ciuhnenco in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Sep 2015, 11:44 am
  2. Arc with START, END, CENTER points?
    By vanowm in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Jul 2015, 02:12 am
  3. How do I center the text in the rectangle and repeat the last input?
    By BrianTFC in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Feb 2015, 08:59 pm
  4. Repeat Last Command
    By ksperopoulos in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jul 2010, 02:53 pm
  5. Arc - Start Center Angle
    By GREG in forum AutoCAD Beginners' Area
    Last Post: 10th Sep 2007, 02:41 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
