Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 23
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,731
    An example of the title block with the attributes filled in.
  2. #12
    Junior Member
    Electrical
    AutoCAD 2018
    Sep 2017
    13
    Hello,
    No, actually, till now I have used the AutoCAD Electrical which was already installed and the basic things were already set up, so just had to play with the schematic diagrams and the enclosure panels.
    Now, this company has purchased a totally new liscence of AutoCad 2018 Electrical and I have to set up the things from the scratch. Till now, I have just made the drawings (without the Tittle block and border settings). It is default.
    I would say, is there any way you can share your premade Electrical Template and I can use/edit the same at my end ?
  3. #13
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,731
    When AutoCAD 2018 was installed you should have been able to migrate over much of what was setup and used in the previous release. You should not be starting from scratch. This would include custom template files.
    I do not have a premade template I can share with you at my present location as I am on the road at the moment and not in my office. The image I posted was taken from the drawing you provided previously. All I did was edit the attributes which worked exactly as I said they would.
    Regarding the cabinet you want to draw. Another option would be to draw it "to scale" much as you would do manually on a drafting board. First you would have to figure out what scale you want to use. The title block and border however would remain real world size which in this case appears to be roughly 420x297 or A3 size.
    One other option comes to mind and that would be to change the drawing units from millimeters to centimeters using the -DWGUNITS command.
    I don't recall AutoDesk providing a template file that was in portrait mode.
  4. #14
    Junior Member
    Electrical
    AutoCAD 2018
    Sep 2017
    13
    Hello,
    Thank you for your prompt responses. Yes, I get that, but basically I have changed my job and at this current workplace they purchased Autocad Electrical, so working on things from scratch.
    Ok, one quick question: can you tell me how can I change the length and width of the complete
  5. #15
    Junior Member
    Electrical
    AutoCAD 2018
    Sep 2017
    13
    Hello,
    Thank you for your prompt responses. Yes, I get that, but basically I have changed my job and at this current workplace they purchased Autocad Electrical, so working on things from scratch. Sorry if my questions sound silly. But I appreciate your help..
    Ok, one quick question: can you tell me how can I change the length and width of the complete block (not the tittle block) so that I can fit my drawings in it ?
  6. #16
    Junior Member
    Electrical
    AutoCAD 2018
    Sep 2017
    13
    Please see the attached picture
  7. #17
    Junior Member
    Electrical
    AutoCAD 2018
    Sep 2017
    13
    Hello,
    Yes, I got it ...
    You were very helpful.
    Thanks a ton.
  8. #18
    Junior Member
    Electrical
    AutoCAD 2018
    Sep 2017
    13
    OK, one last question:
    Currently as you see the tittle block is vertically bottom right.
    How can I change it to the horizontal bottom right ?
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,731
    You would have to scale the entire title block along with its border OR as I suggested previously use one of the other methods I suggested. The problem is the title block and border are in landscape orientation and you appear to want the cabinet drawn vertically and not shown on its side.
    If a template is not available with a portrait orientation then you would have to create one either from scratch or borrow as much as you can from the default template and when completed save it as a new template file not a .dwg file.
    Personally, I'd draw the cabinet in a horizontal position (lying on its left side) retaining the landscape orientation of the template. Rough guess regarding a scale factor: 7.5 but I'm not sure that would be acceptable in a metric based system.
  10. #20
    Junior Member
    Electrical
    AutoCAD 2018
    Sep 2017
    13
    I checked every available method template, but I am not getting a proper template that we can use professionally in US/Canada for our drawings ..
  1. title block basic setup - dwg vs dwt - etc
    By adnet23 in forum AutoCAD Drawing Management & Output
    Last Post: 16th Feb 2015, 11:17 pm
  2. AutoCAD Electrical Title Block
    By waterhg in forum AutoCAD Beginners' Area
    Last Post: 2nd Jan 2013, 09:35 pm
  3. AutoCAD Electrical - Update Title Block Customise Menu
    By AQucsaiJr in forum AutoCAD General
    Last Post: 14th Sep 2012, 01:05 pm
  4. AutoCAD Electrical : Update title block for all sheets in project after modification
    By ganeshnrg2002 in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Oct 2011, 12:59 pm
  5. title block setup
    By jcreech in forum AutoCAD Beginners' Area
    Last Post: 4th Dec 2009, 06:15 pm
