+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2016
    Join Date
    Apr 2017
    Posts
    1
    Default Annotative Dimension Issue with Fractions
    I am having a problem with Annotative Dimensions and fractional inches.
    What appears to be happening is this: when a "space" appears between numbers, letters or symbols in a dimension, the annotative dimension views this as a "new line of text", and places the following numbers, letters or symbols on the next line. I attempted to change the width of the text box, but this does not help, as it is already wide enough. I noticed that when I remove the space between the number 7 and the fraction 1/2 (see images below), the problem goes away; this is what lead me to believe the annotative dimension is treating the space as a new line of text.
    How do I stop annotative text from doing this without having to remove the space? Please help, and thank you.
    Problem image 01 (fraction pushed to second line of text):
    Problem image 02 (text box width does not appear to be the problem):
    Problem image 03 (removed space between the number 7 and the fraction 1/2):
  2. #2
    Super Member bjenk8100's Avatar
    Computer Details
    bjenk8100's Computer Details
    Operating System:
    windows 8 64 bit
    Discipline
    Construction
    Using
    AutoCAD 2018
    Join Date
    Sep 2009
    Posts
    625
    Default
    this format 1'-1 1/8 is what you want. crucial. Looks fine. If i am misunderstand sry. BTW dont ever override or put text over a dimension. If this is not what your talking about I apologize.
  3. #3
    Senior Member dtkell's Avatar
    Computer Details
    dtkell's Computer Details
    Operating System:
    Win7
    CPU:
    Intel I5 4670
    RAM:
    16mb
    Discipline
    Civil
    dtkell's Discipline Details
    Occupation
    Drafter/Designer
    Discipline
    Civil
    Using
    AutoCAD 2014
    Join Date
    Dec 2006
    Location
    San Diego, CA, USA
    Posts
    153
    Default
    Maybe if you modify your dimension style to include a stacked option for fraction format under the "primary units" tab it will give you a look that works.
Similar Threads
  1. annotative text issue
    By bjenk8100 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th Sep 2017, 08:10 pm
  2. annotative text issue
    By col1n in forum AutoCAD General
    Last Post: 2nd Jul 2012, 11:19 am
  3. Annotative block issue
    By markv in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Jan 2011, 02:45 am
  4. Alternate Dimension Fractions instead of Parenthesis
    By Abates7 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th May 2010, 03:55 pm
  5. Annotative Dimension
    By vinod in forum AutoCAD General
    Last Post: 13th Jan 2009, 01:22 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
