+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Forum Deity rkent's Avatar
    Computer Details
    rkent's Computer Details
    Operating System:
    WIN7 PRO 64bit
    Computer:
    Dell OptiPlex 7020
    CPU:
    i7 4790 3.6GHz
    RAM:
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    Graphics:
    AMD Radeon 2GB
    Primary Storage:
    Samsung 480Gb SSD
    Monitor:
    Dell 24" FS (2x)
    Discipline
    Mechanical
    rkent's Discipline Details
    Occupation
    Facilities Design - Semi-conductor manufacturing
    Discipline
    Mechanical
    Details
    Designer: Process Piping, P&ID's, Machine Part Design, Planning / General Arrangement. Facilities Management. Drafting: Electrical, Controls, Architectural.
    Using
    Mechanical 2017
    Join Date
    Nov 2007
    Location
    Lat:35, Long:-106, Elev: 5164'
    Posts
    4,588
    Default
    Quote Originally Posted by eldon View Post
    Doesn't BLEND create a spline? Whereas the OP appeared to want two arcs.
    I do like your solution, quickest and easiest. No need to draw the diagonal line, just snap using the mid point between two points modifier in the osnaps.
    FWIW - The OP didn't mention arcs, just wanted an S curve.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  2. #12
    Quantum Mechanic
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,154
    Default
    Some solutions
    R1=R2 (off^2+dist^2)/(4*off)
    (off^2=dist^2)/(2*off) - R1 = R2 where R1 is known
    AB= ( 2*off*(R1+R2) )^0.5 length of sloping line.
Similar Threads
  1. How to bend on an arc?
    By Ardalee in forum Autodesk Inventor
    Last Post: 13th Feb 2012, 06:22 pm
  2. how to draw 3d bend in autocad 2008 version with given elevations
    By srinu_vasu38 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Aug 2011, 09:54 am
  3. bend
    By TonyBorland in forum Autodesk Inventor
    Last Post: 6th Aug 2011, 03:10 am
  4. Help) How can I bend a 3d
    By Mr guiff in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Sep 2010, 11:11 pm
  5. How to bend it...
    By nikhil in forum Autodesk Inventor
    Last Post: 25th Aug 2010, 09:36 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
