cawokah17 Posted September 18, 2017 Share Posted September 18, 2017 Is there a quick and practical way to get X & Y values on a polyline other than by way of "LIST". because I need the X & Y value just like the 2nd image. Thank you Master. img 1 : https://drive.google.com/open?id=0B1KbDu2x_byvU2F6NlpvNWJrU0k img 2 : https://drive.google.com/open?id=0B1KbDu2x_byvVE9qdmpBLWcxWHM Quote Link to comment Share on other sites More sharing options...
OMEGA-ThundeR Posted September 18, 2017 Share Posted September 18, 2017 You could explode the polyline (so it becomes a LINE) and use EATTEXT to export the starting X and Y points of each line to an excel document. You would mis the last X and Y point though this way, so you need to add it manually or also select the end X and Y points and just delete what you don't need in excel (or some other spreadsheet program). Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 18, 2017 Share Posted September 18, 2017 Just add the write the answer out to this, the co-ords are in a list as (x y) for 2d plines or just use the getcords as a list of (x y x y x y) ; pline co-ords example ; By Alan H (defun getcoords (ent) (vlax-safearray->list (vlax-variant-value (vlax-get-property (vlax-ename->vla-object ent) "Coordinates" ) ) ) ) (defun co-ords2xy () ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z (setq numb (/ (length co-ords) 2)) (setq I 0) (repeat numb (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) )) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 2)) ) ) ; program starts here (setq co-ords (getcoords (car (entsel "\nplease pick pline")))) (co-ords2xy) ; look at varaible co-ordsxy which is a list of vertices (princ co-ordsxy) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted September 18, 2017 Share Posted September 18, 2017 Try this: (defun c:foo ( / s ) (if (and (setq s (car (entsel "\nSelect a LWpolyline :"))) (member '(0 . "LWPOLYLINE") (setq s (entget s))) ) (foreach pt s (if (= (car pt) 10) (mapcar 'princ (mapcar 'strcat '("\nX=" " Y=") (mapcar '(lambda (x) (rtos x 2)) (cdr pt)))) ) ) (princ "\nNothing selected or invalid selection <!>") ) (princ) ) Quote Link to comment Share on other sites More sharing options...
Grrr Posted September 18, 2017 Share Posted September 18, 2017 Hi, try this: ; LWPOLYLINE's coordinates to excel ; Credits to: Lee Mac (defun C:test ( / GroupN e xlapp xlwbs xlwbk xlsht xlcells xlrng msg ) (defun GroupN ( n L ) ( (lambda (f) (f n L)) (lambda (n L) (cond ( (not L) L) ( (cons ((lambda ( / tmp ) (repeat n (setq tmp (cons (car L) tmp)) (setq L (cdr L))) (reverse tmp))) (f n L)) ) ) ) ) ) (cond ( (not (setq e (car (entsel "\nPick LWpolyline: ")))) (prompt "\nNo selection.") ) ( (not (wcmatch (cdr (assoc 0 (entget e))) "LWPOLYLINE")) (prompt "\nInvalid object.") ) ( (not (setq xlapp (vlax-get-or-create-object "Excel.Application"))) (prompt "\nUnable to interfere with Excel application.") ) ( ; (apply 'strcat (mapcar 'chr '(87 114 105 116 116 101 110 32 98 121 32 71 114 114 114))) (vl-catch-all-error-p (setq msg (vl-catch-all-apply (function (lambda ( / i ) (setq xlwbs (vlax-get-property xlapp 'Workbooks)) (setq xlwbk (vlax-invoke-method xlwbs 'Add)) (setq xlsht (vlax-get-property xlapp 'ActiveSheet)) (setq xlcells (vlax-get-property xlsht 'Cells)) (setq i 1) (mapcar (function (lambda (x) (vl-catch-all-apply 'vlax-put-property (list xlcells 'Item i 1 (car x))) (vl-catch-all-apply 'vlax-put-property (list xlcells 'Item i 2 (cadr x))) (setq i (1+ i)) ) ) (GroupN 2 (append (list "X" "Y") (mapcar '(lambda (x) (rtos x (getvar 'lunits) (getvar 'luprec))) (vlax-get (vlax-ename->vla-object e) 'Coordinates)))) ); mapcar (setq xlrng (vlax-get-property xlsht 'UsedRange)) (mapcar '(lambda (prp) (vl-catch-all-apply 'vlax-put-property (list xlrng prp -4108))) '(VerticalAlignment HorizontalAlignment)) ; xlCenter = -4108 (vlax-put-property xlapp 'Visible :vlax-true) ) ) ) ) ) (prompt (strcat "\nError: " (vl-catch-all-error-message msg))) ) ); cond (mapcar (function (lambda (x) (if (eq (type x) 'VLA-OBJECT) (vlax-release-object x)))) (list xlapp xlwbs xlwbk xlsht xlcells xlrng) ) (princ) ); defun C:test Quote Link to comment Share on other sites More sharing options...
lrm Posted September 18, 2017 Share Posted September 18, 2017 You could use a special VLISP program as noted above but if one is not available I would suggest you reconsider using the LIST command and do a copy-paste into Excel. In Excel click the Data tab and then the Text to Columns option and specify a space delimited file and you will have the x and y coordinates of the polyline in separate columns. Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted September 18, 2017 Share Posted September 18, 2017 Try this: (defun c:foo [/quote] hi Tharwat please look at the 2nd image, img2= [url="https://drive.google.com/open?id=0B1...E9qdmpBLWcxWHM"]https://drive.google.com/open?id=0B1...E9qdmpBLWcxWHM[/url] i think OP needs something without prefix "N=" or "E=" ? [code] (defun c:xytest (/ f fn i l ss) ;hanhphuc 18.09.2017 ;test w/o *error* (if (and (setq ss (ssget "_+.:S:E"'((0 . "LWPOLYLINE")))) (setq i -1 l (vl-remove-if-not ''((x)(listp (cdr x)))(entget (ssname ss 0)))) (setq fn (strcat (getvar 'tempprefix)"XY.csv")) (setq f (open fn "w"))) (progn (write-line "X,Y" f) (repeat (1-(length l)) ;;;(print (vl-string-translate "() "" ,"(vl-princ-to-string(cdr(nth i l)))) f) (write-line (apply 'strcat (mapcar ''((x)(strcat (rtos x 2)",")) (cdr(nth (setq i (1+ i)) l)))) f) ) (if f (close f)) (vl-cmdf "start" fn)[color="green"]; if default "*.csv" associated to EXCEL, but slow performance[/color] (startapp "notepad" fn)[color="green"]; recommended fastest[/color] );progn (princ "\nOops! LWPOLYLINE please.. ") ) (princ) ) Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted September 18, 2017 Share Posted September 18, 2017 hi, try this: (apply 'strcat (mapcar 'chr '(87 114 105 116 116 101 110 32 98 121 32 71 114 114 114))) (vl-list->string '( 76 79 76 ) ) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted September 18, 2017 Share Posted September 18, 2017 hi Tharwat please look at the 2nd image, img2= https://drive.google.com/open?id=0B1...E9qdmpBLWcxWHM i think OP needs something without prefix "N=" or "E=" ? Hi hanhphuc. I wrote the codes for the first image HERE . Quote Link to comment Share on other sites More sharing options...
Grrr Posted September 18, 2017 Share Posted September 18, 2017 (vl-list->string '( 76 79 76 ) ) That was just a humbly info, with no commercial purpose. Anyway I always forget about the vl-list->string function, more used with the (apply 'strcat (mapcar 'chr ...)) approach. Not sure if OP wanted the output to excel, just thought to cover up my practice in this section of lisp. Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted September 19, 2017 Share Posted September 19, 2017 That was just a humbly info, with no commercial purpose. Anyway I always forget about the vl-list->string function, more used with the (apply 'strcat (mapcar 'chr ...)) approach. Not sure if OP wanted the output to excel, just thought to cover up my practice in this section of lisp. nothing wrong you've provided a vanilla method, just curious the hidden message, it was creative Quote Link to comment Share on other sites More sharing options...
cawokah17 Posted October 26, 2017 Author Share Posted October 26, 2017 thanks all.. Quote Link to comment Share on other sites More sharing options...
