+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Junior Member
    Using
    AutoCAD 2009
    Join Date
    May 2015
    Posts
    16
    Default Dynamic blocks in acad 2007
    For most projects we need to cooperate with others. These other companies don't always use the same acad version (sometimes newer and sometimes older).
    Lets say I use acad 2016 and I use dynamic blocks in my drawing (lets say a rectangle with a custumable width and height, internal partitions,...) and I use this block several times with different dimensions.
    If I send this drawing to someone who uses acad 2007 (or maybe older), what happens to the dynamic blocks?
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,877
    Default
    Dynamic blocks were introduced in 2006 so saving a drawing to the 2007 file format shouldn't be a problem. Saving to a file format earlier than 2007 the dynamic blocks will appear static (i.e. - in their last configuration).
  3. #3
    Junior Member
    Using
    AutoCAD 2009
    Join Date
    May 2015
    Posts
    16
    Default
    I just mentioned 2007 as an exemple. I thought about an older version without the dynamic block function.
    Are the dynamic blocks fully compatible between version lets say 2007 and 2016?
  4. #4
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,877
    Default
    Pre-2006 the blocks will be static as previously mentioned. From 2006 onward I assume they should function as designed.
Similar Threads
  1. Replies: 1
    Last Post: 16th Oct 2011, 01:07 pm
  2. In ACAD 2008, possible to mirror dynamic blocks?
    By OaklandDan in forum AutoCAD Drawing Management & Output
    Last Post: 10th Aug 2009, 05:52 pm
  3. Any one need 2007 dynamic 3D pipework blocks?
    By Cerberus in forum Blocks, Images, Models & Materials
    Last Post: 5th Jul 2009, 02:06 pm
  4. Building Systems 2007.1 Dynamic Blocks!
    By boreschd in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jun 2007, 05:14 pm
  5. Dynamic ACAD Blocks
    By igulin in forum AutoCAD Drawing Management & Output
    Last Post: 31st Aug 2006, 03:00 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
