Results 1 to 4 of 4
    Senior Member
    AutoCAD 2017
    Jun 2013
    137
    Default "...more recent version of autocad" error
    Occasionally I get the :Can not open drawing because it was created with a more recent version of AutoCAD" error.
    No it wasn't. I created that drawing two months ago, using AutoCad2017, just like I'm using now.
    What gives?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,043
    There seems to be 2 causes for that message. You have eliminated 1.
    Causes:
    •The DWG being opened is saved in a format that is newer than what your version of AutoCAD understands.
    •The DWG file is damaged or corrupted.
    SEE THIS
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,146
    Just to make sure, are you the only one with access to the file, or is there a chance that someone with a newer version opened and saved your drawing with 2018. Windows explorer - right click on the file and select properties will tell you when the file was last modified.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
    Senior Member
    AutoCAD 2017
    Jun 2013
    137
    To follow up, I was able to open the drawing on another workstation then resaved it.. all fixed.
    I suppose that I'm going to have to reinstall AC one of these days. . . .
  1. How can I download the "holes" function in AutoCAD 2013 student version?
    By knattagh in forum Student Project Questions
    Last Post: 3rd Oct 2012, 11:52 pm
  2. Replies: 0
    Last Post: 20th Jul 2011, 12:40 pm
  3. Initializing...; error: AutoCAD variable setting rejected: "cmdecho" nil
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th May 2011, 11:05 am
  4. Continous Error "Fatal Error: Autocad is running out of memory"
    By capricorn in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 4th Aug 2010, 10:40 am
  5. "Americanizing" a non-US version of AutoCAD
    By ppc in forum AutoCAD Drawing Management & Output
    Last Post: 27th Sep 2006, 07:31 pm
