Mtext instand bylayer
CAD
Hello Ronjonp,
dont know formating but when u double click mtext u can change the color or bylayer. but with properties u can change bylayer but it wont change the color. so i want internal of the mtext bylayer.
the HERE
I only need mtext to be bylayer not all object of the drawing. but thx for replying :)
Hello Ronjonp,
Grab the code I linked to and replace the _objecttobylayer function with this:
(defun _objecttobylayer	(obj / layer)
 (cond	((eq "AcDbMText" (vlax-get obj 'objectname))
 (vl-catch-all-apply 'vlax-put (list obj 'color 256))
Is there not a smaller lisp only for Mtext. this lisp is a risk to my drawing with a wrong move. :)
have replace but think i doing it wrong
(defun c:DrawingToByLayer
   ;;  Copyright © 2004 Michael Puckett. All Rights Reserved
   ;;  Forces the entire drawing to "ByLayer" (even xrefs for
   ;;  the lifetime of the session or until an xref reload
   ;;  occurs).
   ;;  Forces block definition child entities to layer "0".
   ;;  Existing attributes are forced to the same layer the
   ;;  parent block reside on.
   ;;  Nominally tested, let me know if you find anything wonky.
   ;;  * Use at your own risk. Please test on a dummy dwg *
       _UnLockAllLayers
       _LockLayers
       _ObjectToLayerZero
       _ObjectToByLayer
       _DocumentToByLayer
       _Main
   (defun _UnLockAllLayers ( document / result )
       (vlax-for layer
           (vlax-get-property
               document
              'Layers
           (cond
               (   (eq :vlax-true
                       (vlax-get-property
                           layer
                          'Lock
                   (vlax-put-property
                       layer
                      'Lock
                       :vlax-false
                   (setq result
                       (cons layer
                           result
       result
   (defun _LockLayers ( layers )
       (foreach layer layers
           (vlax-put-property
               layer
              'Lock
               :vlax-true
   (defun _ObjectToLayerZero ( object )
       (vlax-put-property object
          'Layer
          "0"
       (cond
           (   (and
                   (eq "AcDbBlockReference"
                       (vlax-get
                           obj
                          'ObjectName
                   (eq :vlax-true
                       (vlax-get-property
                           obj
                          'HasAttributes
               (setq layer (vlax-get-property obj 'Layer))
               (foreach child (vlax-invoke obj 'GetAttributes)
                   (_ObjectToByLayer child)
                   (vlax-put-property child 'Layer layer)
   (defun _DocumentToByLayer ( document )
       (vlax-for block (vlax-get-property document 'Blocks)
           (if
               (eq :vlax-true
                   (vlax-get-property block
                      'IsLayout
               (vlax-for object block
                   (_ObjectToByLayer object)
                   (_ObjectToLayerZero object)
   (defun _Main ( / document lockedLayers )
       (setq lockedLayers
           (_UnlockAllLayers
               (setq document
                   (vlax-get-property
                       (vlax-get-acad-object)
                      'ActiveDocument
       (_DocumentToByLayer document)
       (_LockLayers lockedLayers)
   (_Main)
Edited by CAD
(defun c:drawingtobylayer
      ;;  occurs).
      (/ _unlockalllayers _locklayers _objecttolayerzero _objecttobylayer _documenttobylayer _main)
 (defun _unlockalllayers (document / result)
   (vlax-for layer (vlax-get-property document 'layers)
     (cond ((eq :vlax-true (vlax-get-property layer 'lock))
     (vlax-put-property layer 'lock :vlax-false)
     (setq result (cons layer result))
   result
 (defun _locklayers (layers) (foreach layer layers (vlax-put-property layer 'lock :vlax-true)))
 ;; (defun _objecttolayerzero (object) (vlax-put-property object 'layer "0"))
   (vl-catch-all-apply
     'vlax-put
     (list obj 'textstring (lm:unformat (vla-get-textstring obj) t))
 (defun _documenttobylayer (document)
   (vlax-for block (vlax-get-property document 'blocks)
     (if (eq :vlax-true (vlax-get-property block 'islayout))
(vlax-for object block (_objecttobylayer object))
 (defun _main (/ document lockedlayers)
   (setq lockedlayers
   (_unlockalllayers
     (setq document (vlax-get-property (vlax-get-acad-object) 'activedocument))
   (_documenttobylayer document)
   (_locklayers lockedlayers)
 (_main)
;;-------------------=={ UnFormat String }==------------------;;
;;  Returns a string with all MText formatting codes removed. ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  str - String to Process                                   ;;
;;  mtx - MText Flag (T if string is for use in MText)        ;;
;;  Returns:  String with formatting codes removed            ;;
(defun lm:unformat (str mtx / _replace rx)
 (defun _replace (new old str)
   (vlax-put-property rx 'pattern old)
   (vlax-invoke rx 'replace str new)
 (if (setq rx (vlax-get-or-create-object "VBScript.RegExp"))
   (progn (setq str
	  (vl-catch-all-apply
	    (function
	      (lambda ()
		(vlax-put-property rx 'global actrue)
		(vlax-put-property rx 'multiline actrue)
		(vlax-put-property rx 'ignorecase acfalse)
		(foreach pair
			 '(("\032" . "\\\\\\\\")
			   (" " . "\\\\P|\\n|\\t")
			   ("$1"
			    "\\\\(\\\\[ACcFfHLlOopQTW])|\\\\[ACcFfHLlOopQTW][^\\\\;]*;|\\\\[ACcFfHLlOopQTW]"
			   ("$1$2/$3" . "([^\\\\])\\\\S([^;]*)[/#\\^]([^;]*);")
			   ("$1$2" . "\\\\(\\\\S)|[\\\\](})|}")
			   ("$1" . "[\\\\]({)|{")
		  (setq str (_replace (car pair) (cdr pair) str))
		(if mtx
		  (_replace "\\\\"
			    "\032"
			    (_replace "\\$1$2$3" "(\\\\[ACcFfHLlOoPpQSTW])|({)|(})" str)
		  (_replace "\\" "\032" str)
   (vlax-release-object rx)
   (if (null (vl-catch-all-error-p str))
     str
(vl-load-com)
Edited by ronjonp
Hello Ronjonp,
i have try Lee mac lisp and load it, but when i type unformat nothing happen?:o
;;  Arguments:                                                ;;
(defun LM:UnFormat ( str mtx / _replace rx )
   (defun _replace ( new old str )
           (setq str
               (vl-catch-all-apply
                   (function
                       (lambda ( )
                           (foreach pair
                                   ("$1"      . "\\\\(\\\\[ACcFfHLlOopQTW])|\\\\[ACcFfHLlOopQTW][^\\\\;]*;|\\\\[ACcFfHLlOopQTW]")
                           (if mtx
                               (_replace "\\\\" "\032" (_replace "\\$1$2$3" "(\\\\[ACcFfHLlOoPpQSTW])|({)|(})" str))
               str
(vl-load-com)
